What engine is this?
Old Dec 6, 2005 | 05:39 PM
84kabam's Avatar
Car: 84 TA w. t-tops :D
Engine: 350 lookin 4 a 455
Transmission: TH 350
ok so i was at the junkyard today looking for a 455 and came across an engine sitting there and itwas definately a BOP. now i'm really set on finding a Pontiac engine for my car not a buick or olds. The block was surface rusted pretty bad and i couldn't find a cating number anywhere there was only a casting number on the intake manifold and the date it was cast 10.29.74. Removed the intake and the valley pan in hope of finding out which displacement it was a 350, 400, or 455 but couldn't find a number at all! The only thing that was cast in it was C1. So now i'm thinkiong it may be a buick or olds as i'm not as familiar with the two :S Turns out also there's chunks out of the block inside around the crank so it dfefinately can't go in the car but i was thinking i could use it as a mock up.anybody know? thanks
Old Dec 6, 2005 | 07:26 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It's hard to describe each one but if you had pictures I could tell you if it was a BOP or Caddy engine.
I was never a fan of the Buick engines. Lots of people like the Pontiac. Out of the three choices, I'd build an Olds.
Old Dec 7, 2005 | 11:27 AM
84kabam's Avatar
nope no pic sorry but i was also wondering somehting else. I know the 350 the 400 and the 455 all used the same block but i was just wondering where the differnece in displacement comes in? is it just bore and stroke or something else?
Old Dec 7, 2005 | 03:58 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
the blocks are diensionally identical ( or so close it's not worth measuring) the 350 & 400 have the same main bearing size 3", but different bores. ALso, you caint bore the 350 out to a 400. THe 455 has a main bearing size of 3.25".
The .030" overbore on a 400 will get you the standard bore 455. CHeck the sides of the block for a casting of the block size. Also,, peruse the Poncho V8 swap sticky for more info on the Poncho blocks
Old Dec 7, 2005 | 09:29 PM
84kabam's Avatar
not a thing on the side of the block but i think i'll head back out to the yard tomorrow and get some pics of it so i can post them
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
