factory 350tpi drop in question
Car: 1989 Iroc-Z
Engine: 350 tpi
Transmission: Swapped in T5
ok i needed a new body for my trans am cause it got wrecked and i found on with no motor and a 5 speed tranny. the original motor in that car was a 305 i think. my 350 tpi out of my car is auto would the motor out of my car bolt up to the 5 speed tranny in that car. and how much trouble is it gonna be to drop in my motor.
Transmission: 4L80E/4L80E
If it was a V8, yes, your engine will bolt up to it.
How hard it will be depends upon exactly which 305 was in it. If TBI or carb, you'll have a lot of things like harnesses, sensors, fuel pump to switch over. If it was TPI, not too difficult.
1989formula5.7l
Aug 15, 2015 11:35 AM
