blown up 350 tpi
Old Jan 4, 2006 | 12:43 AM
luftgm's Avatar
Car: 88 iroc z 90 gt
Engine: 350 tpi 302 h.o
Transmission: 700r4 5 speed
blown up 350 tpi
Recently I had a connecting rod break on my 350 tpi 88 iroc-z which sent it threw the bottom of the engine. I wanted some advice on rebuilding or replacing the engine. Would somthing like this trash the block, or is it still rebuildable. There was oil and coolant leaking from the bottom of the engine. If it is or isn't. If it was rebuilt, would it be about the same having it built to a 383 cost wise as just rebuilding it. If it isn't rebuildable would the tpi cross over to a 400 sbc?
Or should I just go junk yard hopping for another 350 block.
Old Jan 4, 2006 | 11:27 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard.
The block is now an anchor. Find another.
Old Jan 5, 2006 | 04:03 PM
xomega's Avatar
Car: 1990 chevy camaro rs
Engine: lt1
Transmission: 4l60e
Axle/Gears: 273:(
clean it up some. mount it in the garage and make racing tells up about that block to your buddies. how it was pushing 800+ hp;p and the connecting rod couldnt handle the powah!
Old Jan 10, 2006 | 06:50 AM
beedo's Avatar
Car: 1986 IROC CAMARO
Axle/Gears: 3.73 posi
Sounds like a good plan to me!
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
