Engine mounts
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
Engine mounts
Does anybody have any good pictures of V-8 engine mounts, if so would you mind posting them? I've been looking through catalogs but I can't seem to find the right ones for third gens. The more I look, the more confused I become.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
here's a pic stolen from an ebay item:
http://cgi.ebay.com/ebaymotors/GM-Mo...ayphotohosting
The actual metal mount is two pieces each side, a flatter piece that mounts to the subframe, and a clamshell top that mounts to the motor. The clamshell holds a rubber or poly insert - see below for pic of a set (1 for each side) of poly inserts:
http://www.spohn.net/product.cfm?productid=1363
