v6 swap
Old Feb 24, 2006 | 01:20 AM
sgapen's Avatar
v6 swap
is it possibile to put a 231 v6 in 87 camaro where 2.8 usedto live?the 231 v6 is from skylark 1978
Old Feb 24, 2006 | 03:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, you can.
The question is, "Why?" It will be a lot of hassle, you won't find donor parts that will work (meaning, fabrication), it won't have as much power as most any other swap regularly done, and it will cost more even using (what I assume is) this "free" engine.
You'd get more power out of a 3.4l V6, which is much closer to a bolt-in. 1978 was not the height of Buick 3.8 power by any stretch.
Old Feb 24, 2006 | 04:09 PM
Coult_91's Avatar
Car: 91firebird, 2000 camaro
Engine: 305 tbi,K&N, edelbrock intake & 3.8
Mine as well get a new 3.8l if you wanna do it and just get all the stuff from a fourth gen if you want better 6'er
Old Feb 25, 2006 | 09:35 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
been there, done that (3800 Series II swao). I highly recommend starting out w.a vss cluster (saves the hassle of rewiring more than you need to. New motor mounts fabbed up, I reused the 2.8 frame placement, and it just pops right in. IT looks so damn clean in there it's amazing. I had issues that a tuner would've fixed, but not the $$ to get one (hptuners/digital horsepower) so now I have a 305 in it now (about as powerful as the L36) and weighs more . See my cardomain sight on some swap pics & link on last page when it was in & actually running.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
