Will the car hold up to a LT1
One of my friends has a 1980 Firebird Formula turbo. The engine is a 301 and he is wanting to swap it for a carburated LT1. He is worried that his stock auto tranny and axle will not hold up so I wanted to see what you all thought. Also how hard should this swap be?
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
the first question is, what trans is he running?
The axles should be good as long as he doesn't run on the track every weekend and beat the car at every stop light.
As far as the difficulty of the swap: A carbureted LT1 will bolt in without any mods, except the A/C compressor will hit the engine cradle. A torch and a big hammer will fix that clearnce issue. You are still going to have a wiring dilemma to control the spark from the opti (distributor). Anybody with a wiring diagram and some time can figure this out though.
I personally don't see the benefit of using a carb on top of an LT1. If you already have the FI setup the only hard part is the wiring harness, which you will have to modify anyway.
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
He won't be able to run the auto that came in the car without an adapter plate, it will have a BOP bolt pattern.
Only drawback to not putting the 301 turbo back in, it kills the resale value of the car if he ever wanted to sell it in the future (if it was in really good shape) Buddy of mine has an '80 Turbo T/A with 64k miles and it books for 15k
However, this thread will get locked since it's not 3rd gen related.
Transmission: 4L80E/4L80E
A lot of the TH350's in that time period had dual BOP & Chevy bolt patterns.
Car: 1974 Chevrolet Pro Street Pickup
Engine: Built 454
Transmission: T-400
Axle/Gears: 4.10 soon to be 3.08
No classic car with ANY rust bubbles can be an 8 on the point scale.
My family and I run a classic car dealership out here in Washington state, and the 301's that have come through here have been frame off restorations with full metal working.
I would never classify these cars as being worth it to keep number matching and stock, they just didn't have the drive train to necessitate keeping it stock. The one with the BBC in it sold for way more, as the 301 is...well...crap.
I say go for custom and keep it, you will not get book value for this thing, if thats a CPI guide its
ing you. Classic cars have a street value, along with popularity, no book can ever truly measure that. Line up a 68 camaro and a 301 trans am with the same books and see which one sells.
Sorry for the rant, tell your friend to make his car his own and not worry about value.
ing you. Classic cars have a street value, along with popularity, no book can ever truly measure that. Line up a 68 camaro and a 301 trans am with the same books and see which one sells. Sorry for the rant, tell your friend to make his car his own and not worry about value.
Engine: Built 454
Transmission: T-400
I just realized my error with that, and good! because redoing interiors can be right up there with paint and body work cost wise.
We are located in Port Townsend, Wa
I cruise to East Bremerton with my 3rd gen buddies a lot for the import meet, just to give it a little diversity.
1992 Trans Am
Aug 8, 2015 08:16 PM
