LT1 Swap & Throttle Cable
Old Feb 25, 2006 | 01:52 PM
jfitz1974's Avatar
Car: 92 Camaro RS
I have been working on my 92 RS for 4 years now (off and on) and am just about finished (I redid the interior, changed the rear end out and dropped an LT1 w/ a T56 in her). To those of you who have successfully done the LT1 Swap....how did you handle the throttle cable situation? Did you use the 3rd gen cable with a fabricated bracket or did you use a 4th gen cable? This is one of the few things I have left to do other than hooking up the Painless wiring harness. Thanks for any advice!!!
Jason
Old Feb 25, 2006 | 02:44 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
I believe most folks use the LT1 bracket with the TPI cable..
I went a bit differently and used the Lokar LT1/4 bracket and their high-tech cable, looks different and is braided stainless.. more expensive though..
Old Feb 25, 2006 | 05:44 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
Since I'm cheap, and didnt want to buy a new cable, I used the stock '94 Camaro LT1 cable in my '91 Firebird. It was about an inch to long, so I bent the arm on the pedal to make up the distance and it works great.
Old Feb 26, 2006 | 08:58 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
I was using an LT1 cable, found out it wasn't going WOT and bought a new cable for a '91 T/A or Z28, cost me 19 bucks, cut the little ear off the LT1 bracket and fits like a glove.
Old Feb 26, 2006 | 10:27 AM
jfitz1974's Avatar
Car: 92 Camaro RS
Thanks for the suggestions! I'll give 'em a try.
JF
Old Feb 26, 2006 | 01:07 PM
Firebat's Avatar
If you have thirdgen accelerator pedal - Use the TPI cable and modify the cable or the bracket to make the TPI cable fit.
If you have LT1 accelerator pedal - Use The LT1 throttle cable.
Klortho - do you have LT1 pedals?? Did the LT1 cable not work for you?
Old Feb 26, 2006 | 09:27 PM
Klortho's Avatar
Car: 1987 GTA
LT1 pedals, LT1 cable didn't let it go WOT....I'm thinking they are LS1 pedals instead, so I went with the TPI throttle cable.
Old Mar 1, 2006 | 09:57 PM
LT1powered89's Avatar
Car: 1989 Chevrolet Camaro
Axle/Gears: 2000 rear, 3.73, auburn locker
I tried riggin up a cable and learned the hard way. I spent 45 minutes on the side of the road the day after I finished my swap, trying to rig up the cable again just to get home. I had to get the car towed and I just ended up "borrowing" one off of a buddys car who is building his motor. It is a 1991 TPI throttle cable and it works perfect with the LT1 bracket. My car was originally a TBI car and the TBI cable wouldn't work.
Old Mar 2, 2006 | 09:02 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
I called Street and performance and they sent me a cable for about $16 if I remember right. It hooked up to the throttle arm perfectly, had a plastic grommet to go thru the firewall and hooked to my 87 IROC pedal just right...........Their number is 479-394-5711.........or look them up on-line www.hotrodlane.cc
Old Dec 30, 2011 | 10:31 AM
55ChevyMan's Avatar
Car: 55 chevy Belair & 86IROC Z
Engine: 350 in 55 86IROC Z LT1
Transmission: 55 4speed IROC Z4L60e
Axle/Gears: 12 bolt 410 in55 and 342 inCamaro
Re: LT1 Swap & Throttle Cable
is the 91 Tp1 cabel defferent then a 86 IROC tpi cabel been looking for a 91 tpi cabel picture and where it connects on the TB-body is it the same as the LT1 meaning a barrel shape lead on cabel end and is there a way to just replace the steel cabel part of the cabel
9192camaro
16
Feb 3, 2019 12:21 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
timonator
Aug 13, 2015 11:27 PM
fonzie85
Aug 13, 2015 11:50 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
