305 to 350 swap questions
Old Mar 2, 2006 | 12:58 AM
INTIMIDATOR Z's Avatar
Car: 1987 IROC
Engine: Turbo 293ci 4.8l
ok well i got a 87 iroc with a 305 tpi motor.pretty soon gonna be buying a 350 and from what i understand i can use my stock tpi set-up but jsut need to change my injectors,computer, and knock sensor.
so heres my questions....
what size injectors would i need?
is there anything else that i would need?
also i wanna put a little bit bigger cam but nothing too crazy. what do you guys reccomend?
Old Mar 2, 2006 | 11:37 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
What you've heard is pretty much true, although all you need for the computer is the PROM (aka "chip").
22 lb/hr injectors are what the factory put in 350 TPI cars.
Something along the line of a Comp XE262 would be about all the cam you'd want to put in a stock TPI engine. Is your 350 a roller lifter block?
Old Mar 3, 2006 | 01:49 AM
Car: 1987 IROC
sorry chip. um not sure but i think its gonna be a roller still lookin for one.
probably a dumb question but i kinda like keeping everything legal. will i be able to hook my smog stuff up to it and smog it with the 350 swap?
Old Mar 3, 2006 | 08:08 AM
five7kid's Avatar
Shouldn't be any problem at all. 350's were offered in '87, and they looked exactly like and were equiped exactly like LB9 305's. If you stay with center bolt valve covers there shouldn't be anything that tips them off. Even if they were tipped off, the engine is one that is allowable.
The "final touch" would be to put L98 stickers under the hood. However, since your VIN will say it was an LB9, that might earn you a trip to the Motor Change ref.
Old Mar 4, 2006 | 01:51 PM
BlackRabbitZ28's Avatar
Car: 1991 Z28 5-Speed
Engine: 305TPI
Transmission: 5-Speed T-5
Thats why I hate CA. Back home in Indiana where I register my car there is no inspection what so every. Its soo nice when modifiing the car not having to worry about that B.S.
Old Mar 4, 2006 | 02:17 PM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
Sorry for jumping in on your thread, but I'm doing the same to a 91 GTA. 91 305 TPI sd to a complete 91 350 TPI sd out of a 91 Z. Besides the injectors,prom and the knock sensor is there anything else I need to change? I'm installing headers and exhaust,SLP runners, AFPR and new injectors. I would like to get the HP up to 300. Any suggestions on a cam and inj. size or anything else? Is the stock FPR the same on 305s and 350s? Thx.
Old Mar 4, 2006 | 02:26 PM
Dokken10's Avatar
Car: 91 Formula
I forgot I'm installing a TB airfoil also.
Old Mar 4, 2006 | 02:34 PM
Dokken10's Avatar
Car: 91 Formula
I have to stay emissions legal also.
Old Mar 4, 2006 | 03:44 PM
Car: 1987 IROC
well i found a L98 vetter motor and 700r4 trans on ebay and WON it for $699.00 and since its local i can go get it.
here is the description of the auction.
1985 Corvette L98 engine and trans 700r4, this is a early iron head motor 235hp, runs excellent with just over 100k orig miles. This set up will include complete brackets and accessories plus ecm with engine harness. Unit was well kept and would make a great project donor or replacement, item can be picked up or shipped by carrier. Thanks for looking
so maybe within a month or 2 itll be in there.
possible 305tpi/700r4 with about 135k miles for sale. or part out soon.
Old Mar 4, 2006 | 04:34 PM
Engine: 305TPI
Sweet deal
Old Mar 6, 2006 | 01:11 AM
Car: 1987 IROC
what would you guys reccomend for a mild cam and lifter kit? also rocker arms?
do you guys think i should prot the intake and plenum?
Old Mar 6, 2006 | 02:56 AM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
What is involved in "proting" a intake?
I think you should wait and replace them at a later time.
Why not put that 700r4 in the RS?
Old Mar 6, 2006 | 09:34 AM
Car: 1987 IROC
cuz the RS sux!! its a lemon.
bellez77
Sep 5, 2015 08:39 PM
redmaroz
Aug 16, 2015 11:40 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
