got me a 383 crank
Old Mar 25, 2006 | 09:41 AM
glintscollide's Avatar
got me a 383 crank
whats up guys.site looks good.Im swappin in a 350 block in my 1990 camaro.the block is a 350 4 bolt-main rebuilding.I got a eagle 383 crank.Part number-ESP-103503750 Eagle Cast Steel Crankshafts.I was wondering if any one would know what i would have to do to the engine block to get this to work?Any info would be greatly appriciated.I know imma have to take this to a machine shop,but what should be done?Thanx.
Old Mar 26, 2006 | 12:48 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you may have to clearance the oil pan rails, and another part of the block. you may need to grind down the bolt heads on your conn rods.
Bolt it into your block, and rotate it and check clearance. .060" on everything is needed, if you don't have that, mark it with a sharpie, then grind it down.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gixxer92
Apr 12, 2022 12:09 AM
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Nervous2
Oct 8, 2015 10:53 PM
S10K20
Oct 7, 2015 06:45 PM
