engine swap help!!
Old Mar 25, 2006 | 05:17 PM
drshirk's Avatar
Car: 91 Camaro RS Convertible
engine swap help!!
I am attempting to build a 350 engine for my 91 camaro. I am new at this so I was hoping for some advice. I have the block built already but I need advice on heads and cam selection. I am planning on using the car on the street and I am just trying to get it faster. Someone gave me a set of heads. These http://store.summitracing.com/defaul...=egnsearch.asp and they told me I should go with a comp cam xe268h. I am not to sure about that cam. Will it big to large with the heads. I am planning on using tpi and headers and a good exhaust system. Let me know what you all think.
Old Mar 25, 2006 | 10:47 PM
drshirk's Avatar
Heads
Sorry the link to the heads was wrong. I am going to be using these heads Dart Iron Eagle S/S part number drt-10021070
Old Mar 27, 2006 | 09:24 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
if you got the heads call summit or the cam manufacturer and they will tell u what cam you need.get all your info together first
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
