305 tbi to 406 carb
Car: 1992 25th anniversary camaro
Engine: 406
Transmission: t56
Axle/Gears: 410s
305 tbi to 406 carb
what the hell am i supposed to do with all this wiring??? just cut it off?? i don't really wanna do that. hmm anybody any ideas?
Use what u need to run the carb setup(which isn't much)....and pull back and put the rest in looms and run it neatly along the side or back....it'll look good,and still be present.....there is a right way and a wrong way...lol...the wrong way would be to butcher the harness......I did this with an '89 RS I had.......good luck
Transmission: 4L80E/4L80E
What you don't need will easily separate from what you do need. What you don't need can be removed by unplugging connectors without cutting anything.
....when I said I did this to an '89 RS I had- I DID NOT butcher the harness....lol
