TBI to TPI swap
Old Apr 3, 2006 | 11:01 PM
Giovannetti's Avatar
TBI to TPI swap
Ok I have a TPI L98 motor but a buddy of mine on http://www.z28.com is wanting to rebuild the TBI and and he found a complete TPI motor that needs a rebuild and possibly the harness but he is concerned that he would have to swap out the fuel pump. Any info on this would be great. Thanks
Old Apr 3, 2006 | 11:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The pump will have to be changed, but that's no big deal. Just a few hours of work.
Old Apr 4, 2006 | 01:56 AM
why cant he just slap a AFPR on there and call it a day?
Old Apr 4, 2006 | 02:43 PM
five7kid's Avatar
Because the TBI pump doesn't put out enough pressure to suppy the TPI.
If it's a complete TPI system, it will have the right regulator already. The pump doesn't really matter that much, it's whether it can produce enough pressure and flow that determines if it will work.
Old Apr 4, 2006 | 08:36 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
To elaborate on what Five said a TBI pump will produce no more than 15psi of fuel (lucky if you get 12). This is assuming stock fuel line size. TPI, like any other MPFI system, requires in excess of 45psi. You will need to swap fuel pumps. I would look at the Walbro units. They are cheaper, stronger, and seem to last longer than GM pumps. I had my walbro 255L pump shipped to my door for $97.
Old Apr 4, 2006 | 10:33 PM
ok thanks guys
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
InfinityShade
Aug 22, 2015 08:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
