Distributor Position, TPI
Old Apr 13, 2006 | 11:49 PM
Overspendin''s Avatar
Car: '88 IROC Convertible
Engine: ZZ4 TPI
Transmission: 5 spd.
Installing a new ZZ4 TPI to replace my 305.
What is the correct position for the distributor for initial startup?
Thanks if you can help.
Old Apr 14, 2006 | 12:11 AM
Evil 88IROCZ's Avatar
Car: 88 IROC
Engine: 305 tpi
Transmission: 5 speed
UM....... OK, well make sure the engine is at top dead center at number one cylinder. When you drop the distributor in make sure the rotor is pointing at the number one cylinder. Then when you put that cap on, try to line up the number one connector on the distributor cap over the rotor. Fire that sucker up ( you may have to rotate the cap by hand to get it to start, not often but happens. If it doesn't start just sputters and stuff you are 180 off.) Get your timing light out, let the motor warm up and set the timing for whatever the spec sheet says. That's about it, good luck.
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
86IROC112
Aug 17, 2015 02:00 PM
Out-Cast
Aug 17, 2015 10:57 AM
Sanjay
Aug 12, 2015 03:41 PM
