Thirdgen in2 a Blazer
Old Apr 14, 2006 | 09:49 AM
Shiprekd's Avatar
Car: `96 Firebird
My 90 was tail ended awhile ago and decided to take everything out and stick it in my 85 K5 Blazer.
I started out with a simple mindset and it turned into everything from roller rockers to fluid damper, small chamber heads, you name it.... $415 for Tubetech fuel lines and another $600 for an EFI tank, pickup assy, and a GM 1LE f.p.
Yesterday I connect the ECM, prime the oil pump and turn the key....
Sputter, sputter... She tried to start but couldn't get past that. SO I check the usual spark/timing thing and look for codes. Awesome spark (new billet dist. w/msd coil, Taylor wires,etc...)
Since I don't have a fuel pressure test gauge (daughter used the one I had for checking dirt pressure..lol), I wrap a couple rags up and give the fuel rail schrader valve a quick hit and what do I get? a dribble.... LOL
Surely all that money and planning obviously didn't include one thing...
A NEW FUEL PRESSURE REGULATOR!!!!!
After mumbling quite a few explatives I realize that you can plan and execute a really expensive and kewl swap. but all of it just isn't going to go anywhere if you forget the basics.
Old Apr 14, 2006 | 10:34 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
looks pretty, but my truck is bigger
Old Apr 14, 2006 | 10:41 AM
Shiprekd's Avatar
Car: `96 Firebird
LOL...
Two things have kept me from lifting it more. PA Vehicle code and that 25ft Sea Ray in the background...
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
bryan623
Aug 10, 2015 11:33 AM
anesthes
Aug 8, 2015 09:37 PM
