LT1 rebuild question
Old Apr 15, 2006 | 07:10 PM
djr_678's Avatar
Car: 98 T/A 94 dodge ram
Engine: LS1/ 5.9
I'm rebuilding a 95 LT1 out of 9C1 caprice for my 92 RS
Is the water pump drive under the timing cover serviceable because the when i spin the shaft i feel drag almost like the bearing is bad, but everything is tight when I removed the retainer and i couldn't remove the shaft is it pressed in?
TIA
Dave
Old Apr 17, 2006 | 03:04 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
The shaft is pressed into the bearing. Some slight tapping with a ford tool will work to get it out. The bearing is replaceable but I do believe it is a dealer only item. You may be able to get a number off of it and cross it.
Old Apr 17, 2006 | 04:40 PM
djr_678's Avatar
Engine: LS1/ 5.9
Thanks I'll give it try tonite, if it gets FUBAR guess I'll be using a eletric water pump
midge54
Dec 27, 2019 04:14 PM
87iroctheo
Dec 4, 2016 11:47 AM
fbirdroller
Sep 2, 2015 10:27 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
