Putting in a new motor...
Old Apr 26, 2006 | 04:00 PM
jmoney843's Avatar
Car: 89 Iroc Z
Engine: 350TPI
Is there anything i need to know about pulling the 350TPI and 700r4 and sliding in a turbo 350 and carb'd 400 small block? Any problems with room...also if anyone has a manual or a site to help me though this, itd be greatly appreciated.
Old Apr 27, 2006 | 10:49 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Read the sticky's on the top of the engine swap forum and use search. and a 400 will fit just as good as a 350 and the tranny will fit fine, but if I am not mistaken you will need a different driveshaft. There is much material on this.
Old Apr 30, 2006 | 01:38 PM
fbodyguy86's Avatar
Car: 92 camaro rs
also will need to get a bracket assembly i believe band m makes it to bolt the torque arm to the differnt tranny
thanks
Jake_92RS
Jan 28, 2020 10:37 PM
dyeager535
Aug 28, 2015 08:10 AM
michealleger
Aug 26, 2015 03:29 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
Fronzizzle
Aug 9, 2015 01:15 PM
