computer harness
Car: 1991 camaro rs
Engine: 3.1
computer harness
my dad and i going to be pulling a 305 tbi out of a 91rs to install into my v6 91rs. my question is why can't i unhook all the wiring from the computer and and leave the wires hooked to the sensors?seems to me this will aid in remembering where everything goes when in the v6 car. i'm planning on using the same computer out of the donor car so all the hookups ill be the same right?
Transmission: 4L80E/4L80E
First, take pictures of the overall engine bay of both cars, with detail photos where things are (firewall, particularly).
Next, disconnect the computer harness from the passenger kick-panel pass-through connector. Pull it into the engine bay. Disconnect all of the parts from the car that the harness connects to that aren't on the engine, and set them with the engine. Be sure to label what you disconnect so you know where it goes when you get back to putting it in the new car.
You could do the same thing and disconnect it all from the engine, and pull the harness/sensors out separately from the engine. That's basically what I did 7 years ago.
You haven't been to an assembly plant, have you???
Reason I ask is, THATS EXACTLY HOW THE CAR WAS PUT TOGETHER IN THE FIRST PLACE. When the motor was put in the car, there wasn't some guy fishing wires through hoses and brackets and whatever else as the car rolled down the line; instead, all of that was already hooked up to the motor at the motor plant, and they just uncoiled the main harness to the ECM, ran it into the pass compartment, and plugged it in.
So yes, you absolutely CAN do it that way; and it might be a whole lot less work in the long run. In fact, that's exactly how I would do it, if I was doing what you're doing.
Car: 1991 camaro rs
Engine: 3.1
i just hate fishing around trying to figure out where a vacuum line or power wire goes and figure heck, it all combines into close to 1 or even 2 hookups, why not try and do it this way. you know the looms are usually bent and turned in the direction they need to go. hopefully this will work! i can't start the project until "next friday" (puff puff) lol so i'll keep ya'll informed.
Car: 1991 camaro rs
Engine: 3.1
ok fellers.what am i going to have to purchase for the new engine before the swap project will be finished??? i know i 'll have to have a set of exhaust gaskets and a good battery what else will i "have" to have to make this baby run!!! i am planning on later after all of the bugs are worked out putting in new poly. mounts because right now i'm on a "set"
budget... any help would be greatly appreciated along with what i have recieved already.. by the way if it weren't for you guys i wouldn't have even thought about this project but all that i have read and learned on here. thanks mike
budget... any help would be greatly appreciated along with what i have recieved already.. by the way if it weren't for you guys i wouldn't have even thought about this project but all that i have read and learned on here. thanks mike Thread Starter
Car: 1991 camaro rs
Engine: 3.1
got the other camaro over to the house pulled the fenders hood radiator support and radiator, had to get a saw zaw because it was wrecked pretty bad but the engine is all good does turn over getting ready to unbolt everything now! can't wait to hear the 305 start up especially drive it down the road!!!
Car: 1991 camaro rs
Engine: 3.1
pulling both engines tomorrow!!! just have to unbolt the torque arm out back!! the donor car had the fender off when i pulled the harness from it but my white rs still has the fender how can i get to the v6 harness without taking the fender off??
Car: 1991 camaro rs
Engine: 3.1
AWSOME!!!!! took the harness out today, the exaust took apart and laying next to the car also took the torque arm off!!! when i took the arm off, the tranny and engine tilted almost all the way down!! i am so excited tomorrow we are pulling the old 3.1 and hopefully installing the newer L03!!! thank for the advice on the inner fenderwell it was a piece of cake when i took it off!!
gczj13
Sep 18, 2015 01:09 PM
Billy Decker
Sep 4, 2015 03:46 PM
