LS1 swapping into my 3rd gen T/A
Old May 8, 2006 | 10:35 AM
tuske427's Avatar
Car: 1984 Trans Am
Engine: 2002 LS1
Transmission: 6 speed
Axle/Gears: 3:73
HI:
This weekend some friends and I were performing the LS1 swap into my 1984 Trans Am. Engine/ trans is an '02, and the engine mount kit is from F-Body motorsports.
I'm discovering the following issues, and was wondering if you have any suggestions for solving them.
1- the AC compressor won't fit. Obviously, the compressor interferes with the crossmember. I don't know if there's another compressor that would fit. I don't have the welding/ fabrication skills to modify the crossmember. For now I'm foregoing the AC but since I'm in CA I'd like to use it if possible. Any suggestions?
2- The windshield wiper motor interferes with the smog equipment and fuel rail for the engine. I can relocate the smog part, but not the fuel rail. Is there any other wiper motor that would be smaller/ mount slightly different to clear the fuel rail? My wiper motor does not have delay, either, (if it matters. I think I remember the older cars having larger wiper motor assemblies if they had wiper delay)
3- How do I bleed the hydraulic clutch cylinder? Do I do this before I install it onto the clutch/ bellhousing? Can I use any hydraulic fluid (power steering fluid) or is there specific "hydraulic clutch cylinder" fluid?
4- Is there any factory bellows/ air tubes that will work on the third gen car for locating the MAF and the air inlet temp sensor? Not sure if I can grab something from a junkyard or if I need to get one from a junkyard.
Any experience or suggestions would be greatly appreciated.
thanks!
Old May 8, 2006 | 10:39 AM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
Originally Posted by tuske427
HI:
thanks!
There is an entire forum dedicated to LS1 swaps. hop over there and just look through some of the posts. or search!
The AC compressor will not fit, you will have to modify the K-member or buy a tubular one for it to fit.
Old May 8, 2006 | 01:09 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
I responded to your thread over at LS1tech.com....
Old May 14, 2006 | 11:45 AM
tuske427's Avatar
Car: 1984 Trans Am
Engine: 2002 LS1
Axle/Gears: 3:73
thought I was in the engine swapping forum. OK, I'll look for another.
while I'm here I'm having trouble withthe exhaust, too.
My goal is to make this emiisions legal, yet nothing seems to be going my way.
Both exhaust pipes/ cats need considerable modification to even fit in my car. I thought these were supposed to be a bolt up deal.
The fuel rails are another nightmare...
Frozer!!!
Jan 19, 2024 04:55 PM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
