What 350 can I put in 86 Trans am?
Old May 10, 2006 | 11:50 PM
juansupreme's Avatar
Car: 86 Trans Am
Engine: 350 Roch-4bbl
Axle/Gears: Normal
I got an 86 trans am with all original conponets. (305), 994856 original miles on.. it had it for 5 years.
What (and where), kinda 350 motor can I put in her and swap all conponents to the 350 motor?
Rochester 4bbl Carb, intake manifold, exhast pipes, smog pump, water etc etc
I'm not lookin to spend alot of money just want a working 350 (block and heads) and move my stuff to it.
Please Help.
Tapped out looser
Old May 11, 2006 | 01:30 AM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
I put a 350 4bolt from an 83 suburban in mine...anything from 82 and up will drop in no problem...i just dropped a 1980 305 in mine because the 350 blew up....the only difference is the location of the oil dipstick tube in the oil pan and on the driverside....and the oil pan is longer at the bottom and hits the exhaust.....
Old May 11, 2006 | 12:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Guess what? The '86 is a "bastard" year. It has one-piece rear main seal crank, which changes the flywheel/flexplate type. It has '86-earlier intake manifold bolt patter (which is a good thing).
So, technically, the only thing that will "drop in" is an '86.
But, all you're looking at is a $40 flexplate if you get an '85-earlier 350. If you get an '87-later engine, you're looking at elongating the center two mount bolt holes on each side of the intake manifold. If you get a '79-earlier engine, the aforementioned dipstick location is going to cause problems with stock exhaust manifolds. But, the stock exhaust is terrible, seriously consider headers while you're at it (which would solve the dipstick tube problem with '79-earlier engines).
In fact, if you don't get headers, forget the 350 entirely and spend the money on a new cam and exhaust for the 305.
And I am dead serious about that.
Old May 11, 2006 | 12:32 PM
Car: 86 Trans Am
Axle/Gears: Normal
Cam What Cam?
Hi thanks for respondin.
what kinda cam can I use(veriety)
Also, I'm lookin to do the work myself, I got the mechanics knowledge of what ever the 86 firebird service manual says to do...is there any cams out there that requires just puttin it in the engine block and go?
Old May 11, 2006 | 01:02 PM
five7kid's Avatar
You need a flat-tappet, computer-compatible type. The Comp XE262 is a decent choice, as is the Crane Powermax 2050. Both need the exhaust upgrades in order to work properly.
If you aren't willing to go with a higher stall torque converter, you shouldn't go bigger than something like a Comp XE256. That's still a big jump over the stock cam.
theshackle
Sep 17, 2020 08:26 AM
camaro11j
Sep 19, 2018 08:49 AM
camaro71633
Sep 1, 2015 10:24 AM
milk
Aug 10, 2015 06:26 PM
Leggman1
Aug 6, 2015 04:15 AM
