motor question
Old May 14, 2006 | 07:51 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
motor question
how much horsepower does the 305 carb motor and the 350 carb motor have,,
Old May 14, 2006 | 11:19 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
not much
Old May 14, 2006 | 11:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The LG4 had 145 to 170 HP, depending on the year. The L69 had 190 HP.
There were no carbed 350s in thirdgens.
Old May 15, 2006 | 02:36 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
i have a 86 camaro z28
Old May 15, 2006 | 03:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Then if it's stock, you've got either a 165 HP LG4, or a 190 HP L69, both of which are 305s.
If it's not stock, then who knows what you've got.
Old May 15, 2006 | 08:14 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
i dont have a 305, i have a 350 5.7
Old May 15, 2006 | 08:17 PM
hotshotcamaro's Avatar
Car: 89 camaro RS
this is where i usually go for engine info on thirdgens http://pontiac.cz/engines.php
Old May 15, 2006 | 08:19 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Then it's not stock, and asking how much HP it has is pointless, because nobody knows how it's built.
Old May 15, 2006 | 08:21 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
i just want to know the basic hp, i know it has headers, its got a stock cam, which im replacing, and elbrock carb and air filter,
Old May 15, 2006 | 08:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Stock 350s came with anywhere from about 140 HP to over 300 HP, depending on the year and the appication. Modified engines can be higher. Your guess is as good as anyone's what it is, without starting to take things apart to actually see what the engine was actually built with.
Old May 15, 2006 | 08:30 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
thanks, thats what i wanted know, i will go get it dynoed and see what happends
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Cleotiz
Jan 6, 2018 08:56 PM
PestilenceIV
Aug 20, 2015 02:33 AM
redmaroz
Aug 16, 2015 11:40 PM
