305vortec to 350vortec
Old May 20, 2006 | 11:14 AM
kaptinkafeen's Avatar
I am needing some technical info regarding swapping out a set of 305cid vortec heads for 350cid vortec heads.
My current combo was assembled by the previous owner - 355cid, 305vortec heads, edelbrock intake and holley750 avenger. As expected, the engine begins to 'run out of breath' at about 4800rpm, and I am in search of a good 'fix for the problem, without having to purchasing too many new parts at this time. I am curious, can I bolt on a set of 350vortec heads with no modification to the current set up. I have heard two stories - one tells me that I would have to swap out the current pistons while others have suggested that I could 'bolt on and play' with the 350 heads?
Can anyone enlighten me or steer me in the direction of some tech info as to what needs to be done.
I guess I would like to be able first, just put on the better breating heads, without having to take apart my short block, but if this isn't an option and pistons, cam/lifter/rockers need to be changed then this is the route I will take.
TIA guys
-Andrew
Old May 20, 2006 | 09:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If the engine was put together for about 9.5:1 CR with the 58cc 305 heads, it was most likely done with dished pistons so it will be at least a half point lower with the 64cc 350 heads. Up to you whether you live with the lower CR, shave the heads down to 58cc, or put in new pistons.
budget builder
Carburetors
May 8, 2012 05:37 AM
mikel1750
Jan 5, 2011 06:41 AM
RGV 89 GTA
Mar 27, 2010 11:01 PM
girlmit91
Dec 2, 2008 11:42 AM
91SacMaro
May 24, 2008 01:36 PM
