tpi to carb engine
Old May 23, 2006 | 12:13 PM
liquidirocz's Avatar
Car: 1986 iroc-z
tpi to carb engine
Hey guys i have a few questions about doing this swap. i am going to put a carb 383 in my tpi iroc. i want the engine bay to look clean, so im thinking of taking out the engine wiring harness and buying a new harness for a 3rd gen with a carb if they make one. Where can i find a new harness for my application?? Also what else am i gonna have to change besides the sending unit in the tank, and gas gauge? And if anyone has any other things that they would like to add i would greatly appreciate it!!!
Old May 23, 2006 | 02:52 PM
irocalot's Avatar
I guess the answer here depends on how far you want to go with the "clean" look...
All a small block really needs to run are hot leads for the starter and distributor, and an alternator wire is a good idea if this is a street car, so you could just cut everything but those off.. of course your gauges would stop working then...as would your A/c and cruise control...
Old May 23, 2006 | 02:58 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
https://www.thirdgen.org/carbswap
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
