Engine mounts help please!
Old May 24, 2006 | 12:04 PM
jonny86's Avatar
Im putting a 350 into my 2.8l v6 berlinetta, I was wondering were I can order the right engine mounts for the new 350, thanks alot
Old May 24, 2006 | 12:13 PM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
You can get the engine mounts from any auto parts store. just get them for
same year V8 car. you will also need the "clam shell" part of the mount that bolts to the engine block. I got mine from gm when I did my V6 to V8 swap.
Old May 24, 2006 | 12:25 PM
jonny86's Avatar
thanks alot
Old May 24, 2006 | 12:30 PM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
np...one other thing I just thought of.....you have to move the brake line that runs across the engine crossmember. It will be obvoius when you install the mounts.
Old May 26, 2006 | 05:40 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
get the clamshells...( engine mounts ) from a u-pullit type yard. GM will want around 50.00 to 60.00 for them
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
