Sensor Help Required!
OK, I got the 350 from the motor shop today, been working on transferring over all the stuff from my 305. I have 2 questions.
One, There is a sensor that is right above the oil filter. What is this thing called? And what is the best way to get it out? it doesnt appear to have a nut on it, it looks like maybe it requires a special tool ??
Two, The sensor on the passenger side Head that appears to measure coolant temp. What is this called? It is missing the little tab for the wire to plug into, so I need to replace it.
Any help is much appreciated here guys.
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
#1 oil pressure switch, it should have a metal base on it that you can grab with some pliers.
#2 coolant fan switch, this turns on the fan when it gets to temp.
[GA] Shorty headers
Night rider327
Sep 16, 2015 02:20 AM
FormulasOnly
Sep 10, 2015 09:07 PM
