TBI-CARB wiring questions! help
Old May 29, 2006 | 08:48 AM
chevycamaro91's Avatar
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
Axle/Gears: posi 373
what do i do about all my sensors? didnt they all work off the computer?
Old Jun 3, 2006 | 03:37 AM
kboehringer's Avatar
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
Sensors?
chevycamaro91,
I'm not familiar with your project. Maybe you've got another post(s) where some of the TGO Guys are more familiar with this. I just noticed that nobody had offered anything and it had been a couple days......... So I'll TRY to help...
What "SENSORS" are you talking about? Your Water Temp, Oil Pressure, Tachometer should work......There are multiple other PROBLEMS you'll have to overcome with eliminating the ECM on a '91.
What's your plan? I hope you don't have emissions in you area of PA yet! Please provide more info.
Kurt
Old Jun 3, 2006 | 08:16 AM
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
i just want all my gauges to work like they do now. yea liek temp/bat/tach/speedo/oil. and no emissions will not be a problem. i think i read the big thread on the project you and your son did(if i remember correctly). you did the same sorta thing right?
Old Jun 3, 2006 | 09:30 AM
Car: 1982 - Z28
Originally Posted by chevycamaro91
temp/bat/tach/speedo/oil. ........you did the same sorta thing right?
chevycamaro91,
Yes.... SORTOF.... We did a similar thing BUT we opted for completely computer controlled. We used a Rochester E4ME and replaced the ENTIRE wiring harness & ECM/computer with one from an '86 Carb'ed Z-28. The reasons for our choice are numerous, and I think we made a good choice and avoided many of the pitfalls others have had to overcome.
NOW TO YOUR CAR!!
I'm sure there will be folks that will correct me if I'm wrong but I believe you have several additional problems to resolve with your '91 than we had with the '82.
From what I've gathered over the last year or two....
The Temp, Bat, Oil & Tach should work just fine. Speedo is probably another story..... I don't think you have a Speedo "Cable" as your speedo is somehow electronic via the ECM? (Not too sure but I read something about this a while back). If your ECM is disabled (or just not functioning properly) I don't believe it will properly "Lock-Up" the Tranny. Timing advance which is generated by the ECM with inputs from the Knock-Sensor and Emission Sensors will also not function properly. I assume you've overcome the electric fuel pump problems and the car is running since your worried about the gauges?
I guess I haven't been much help at all..... we really need someone to chime in that has more familiarity than I have with the newer thirdgens.
Sorry I couldn't provide real assistance....
Kurt
Old Jun 3, 2006 | 10:05 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Assuming you removed the ECM altogether....
Everything will work fine, except tach. You'll have the cut off the plug into the computer controlled distributor, seperate the wires, crimp on ends, and plug them into your new non-cc HEI distributor - one for BATT, and one for TACH (you did swap in anon-computer controlled HEI distributor right?)
All else works fine, including speedo.
Like mentioned, you'll also need to install a torque converter lockup switch kit if it's an auto tranny, as the ECM won't be there, and can't control the torque converter. This requires dropping the pan (good time for that shift kit install & new filter while there), and swapping the 4th gear solenoid, installing the included wire harness, and installing the included vacuum-controlled switch to lock the converter. Everything will be in the kit - they go for about $80 - $200 depending, B&M, TCI, and several other make them - available at Summit.
Old Jun 7, 2006 | 12:41 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
[hijiacks thread, sort of] if keeping the ecm plugged in, but going old school carb & dizzy, will the lock up switch from the tech article work, or will the aftermarket lockup switch still be needed?
linky: https://www.thirdgen.org/torqueswitch
thanks
edit: n/m, will just buy a kit & let engien vacuum do it's thing. will leave up just incasae someone else asks the question.
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
