383z
Old Jun 7, 2006 | 02:23 PM
phoronZ's Avatar
Car: 1989 Iroc-Z
Transmission: 5 Speed
383z
[IMG]C:\Documents and Settings\tsccgy41.AM\My Documents\My Pictures\my roc\backmod.jpg[/IMG]
[IMG]C:\Documents and Settings\tsccgy41.AM\My Documents\My Pictures\my roc\sidemod.jpg[/IMG]
[IMG]C:\Documents and Settings\tsccgy41.AM\My Documents\My Pictures\my roc\engine.jpg[/IMG]
Here it is; THE PROJECT as my friends call it. 383 hsr all forged internals. edelbrock victor jr heads about 10.2 cpr. 1.6 full rr, 226/232 cam. new t6 from a 95 lt1, spohn coil overs on all four corners. KYB agx struts up front. c5 z06 brakes with cross drilled and slotted rotors zinc coated on all four corners. 3.73 posi rear end from a 97 30th anniversary 4th gen ss. Dash replaced with all autometer gauges and a dakota digital convertor for the ecm and speedo. REAL C6 rims purchased from Lingenfelter performance 19x10 78mm offsets on rear strapped with 285/35zr19's falken 451's front has 18x8.5 56mm offset strapped with 265/35zr18's, used 1.7" wheel adapters from skulte performance. I tried the 2.25" adapters and were just too much, there are no clearance issues with the 1.7's. On the rear I had to rubber mallet a few spots but no probs with a 5/16" spacer in place. ANy questions or comments than please respond. I have a lot of tuning and setup left to get it just right so I will be around alot to ask question. Thanks guys.
Old Jun 7, 2006 | 02:30 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
you cannot hyperlink pictures from you hardrive. you will need to either upload them to a place like photobucket or cardomain. sounds like quite the car, i'd like to see the picks.
Old Jun 7, 2006 | 02:32 PM
phoronZ's Avatar
Car: 1989 Iroc-Z
oops sorry...here they are
Old Jun 7, 2006 | 04:41 PM
allsound's Avatar
Car: 1987 Camaro Z28
Engine: 305 carb for now
Transmission: 5 speed
lovin it! Very clean. I like the back end although I find it very plain so I'm surprised I like it. But wow... PM if you ever come up to see your northern brothers in Canada!
Old Jun 7, 2006 | 07:43 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
Question where do you put your licences plate? i want those valve covers those things are pricey.
Old Jun 7, 2006 | 08:27 PM
86birdHT's Avatar
Car: 2004 Pontiac GTO
Axle/Gears: IRS 3.46
When i saw the picture i saw a hint of Photshop being used.
Just a creative way on covering the license plate # i guess.
Old Jun 7, 2006 | 09:32 PM
mw66nova's Avatar
Engine: 7.0L
that was what i was thinking as well.
anyhow, very nice ride my friend, good luck with the tuning of that beast!
Old Jun 8, 2006 | 12:31 PM
phoronZ's Avatar
Car: 1989 Iroc-Z
yes I paint shop pro'd the license plate by extending the light covers... Thought it looked pretty good for a quick job. Actually the side pic has the handles shaved off the same way, might make it real this winter. Everything else is genuine. BTW that is the original 17 year old factory paint job.
I am in Canada.. where are you?
Old Jun 8, 2006 | 02:40 PM
allsound's Avatar
thats insane for the original paint! I'm in ottawa ontario... same exact style car except in black... my paint is very similar so I'm wondering if maybe I have the original paint on as well??? Guess i'll have to check out the VIN What area are you in?
Old Jun 8, 2006 | 07:04 PM
phoronZ's Avatar
Car: 1989 Iroc-Z
I know, there are a few imperfections here and there but overall the paint is in excellent condition. Car behind it is my wife's brand new mazda 3 with the whole paint protection package and everything and if you walk by it wrong a new chip shows up. I'm in Cochrane Alberta, which is ten minutes west of Calgary.
