Big Block 3rd Gen goes the distance on Power Tour
Old Jun 13, 2006 | 02:17 PM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
I thought you guys might be interested to know that my '87 IROC with a 427 big block went 1,700 miles on this year's Hot Rod Power Tour. It sat through grueling traffic without overheating, ran through the curvy Blue Ridge Parkway on it's drag radials and skinnies, traversed train tracks without hitting the exhaust, ran bottom 12's at Gainesville and South Georgia, and, at the end of the Tour, ran 11's at Englishtown. I'm a happy camper.
Old Jun 13, 2006 | 02:23 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Excellent! Back in teh day, I used to take my 8-71 blown 454 up and down highway 1, and broke mostly drive-
train pieces not motor....
Old Jun 14, 2006 | 09:02 PM
CYARS92's Avatar
Car: 92 Camaro RS, 72 Camaro SS
Engine: 305TBI, til it pukes
[QUOTE=Neil87Z28] I'm a happy camper.QUOTE]
As you should be! Way to go. I'm jealous as hell.
Old Jun 14, 2006 | 10:20 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
COOOOL!I am just finishing my BB swap,so nice to replace radical with cubic inches.If you don't mind me asking,what size rear tire are you using,and did you do any modifying to get them in there?
Old Jun 15, 2006 | 03:49 AM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
WTG! That is good to hear(or read).
Old Jun 15, 2006 | 08:49 AM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
I have 275-60-15 Nitto Drag Radials on the rear. The wheels are 15x8" with 5.5" backspace. The inner wheel well had been clearanced by a previous owner in order to fit L60-15 MT Sportsman SS tires. The passenger side fender lip required rolling due to a slight rear end offset to the right.
Old Jun 16, 2006 | 12:52 AM
Pontiaddict's Avatar
Sweet car.
What kind of milage did you get on the Power Tour?
What trans and rear end are you using?
Old Jun 16, 2006 | 02:44 PM
89TPI350's Avatar
Car: 1989 Formula 350
Transmission: 700-R4
wow I bet that was really fun. I would love to do that someday
Old Jun 16, 2006 | 09:19 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i saw you run at englishtown
Old Jun 16, 2006 | 09:55 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Glad ya made it ok!! We were also on the power tour.
Old Jun 17, 2006 | 10:42 AM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
Originally Posted by Pontiaddict
Sweet car.
I just added up my receipts. I used 145 gallons in 1,754 miles, so I got 12 miles per gallon. Not too bad for a big block with a 750 Holley double pumper, TH350 (no OD), and 3.73 rear gears. I spun it on the highway 3,000rpm all day long. It actually gets better mileage than my stock 454SS pickup.
Nice ride. There were several nice third gens on the tour.
Old Jun 17, 2006 | 04:52 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
motor pics?
Old Jun 18, 2006 | 09:25 AM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
Originally Posted by xpndbl3
motor pics?
Here are a few pics...
Old Jun 18, 2006 | 12:19 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
Excuse me, i have to go change my underwear after looking at that car!!!
Old Jun 18, 2006 | 01:03 PM
xpndbl3's Avatar
Car: 1984 Z28
i'm impressed it all fits under a factory hood. good job.
Old Jun 18, 2006 | 03:06 PM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
To get it under the hood, it requires the Edelbrock Torker II-O intake, the flat air cleaner lid, and some trimming of the hood's inner structure. Plus, there's no room for a nitrous plate (the solenoids are in the air cleaner). I had some issues on the Tour with the nitrous and did not make a pass on the bottle.
Old Jun 18, 2006 | 05:03 PM
Irockz's Avatar
What's your best pass to date on spray?I'm curious,as I just finished the swap to a similar 468 in my car.
I'm itching to get it to the track,just wanna get things dialed in a bit better first.
Old Jun 18, 2006 | 05:24 PM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
I have not made a pass on nitrous yet. Best N/A pass is 11.91@115 so I'm expecting low-11's on a small shot. It doesn't have a cage so below 11.49 gets me sent home anyway.
Old Jun 18, 2006 | 08:38 PM
amerikan_rhino's Avatar
Sweet ride! could you post a link to your cardomain website! I havent been able to come across it I'm building a 496 right as we speak for my '86 IROC and wanna see what all you guys have done to get them to go in (mine should be in in the next few months)
Old Jun 18, 2006 | 09:58 PM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
My site is pretty lame because I really only use it to host photos, but here it is:
http://www.cardomain.com/ride/515786
Old Jun 29, 2006 | 12:38 PM
niceroc's Avatar
Car: 87 iroc
Engine: 454 .030 over
Transmission: th-350
Axle/Gears: 9 bolt
what kinda cam/ heads/headers are you running?
Old Jun 29, 2006 | 01:23 PM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
The heads are 1968 -063 oval ports.
The headers are Hooker 2226 BBC 1 7/8" swap headers.
The cam is unknown because a previous owner built the motor. My ear tells me it's approx. 240-250@.050 on a 108 or 110. Idles at 1,000rpm in neutral and 750-800rpm in gear. Pulls hard to 6K+.
Old Jun 30, 2006 | 04:35 PM
niceroc's Avatar
Car: 87 iroc
Axle/Gears: 9 bolt
hummmmm... sounds good.... im build a 454 right now with 781 o-port heads, im going to run a cam a little smaller then yours.. porlly like a xe274 or voodoo276.... hoping to run some times like yours! nice car... i love it...
Old Jul 2, 2006 | 12:12 PM
ShaunZmuders's Avatar
Car: 1989 camaro IROC-Z G92
Engine: GM 355
Transmission: Mad Dog 700R4
Axle/Gears: 3.27 :(
let me just start off by saying that this is one of the most beautiful cars I have seen on this site, really great job you have done, i would love to do a project similar to this in the future and i was just wondering what kind of budjet would i be looking at if you dont mind?, thank you so much for creating this beast haha gives the rest of us somethig to look up to
Old Jul 2, 2006 | 11:14 PM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
Unfortunately, I cannot take credit for the BBC swap. The swap was nicely done, and it is a 31,000 original mile car with original paint. When I bought the car, it needed minor paint/detailing and a bunch of little things to make it reliable. I have added an aluminum radiator, fuel pump, trans mount, alternator, misc. gaskets, plug wires, Mufflex 4" exhaust, nitrous solenoids, pinion seal, new tires, and manual brake pushrod. I also repainted the front end and painted/detailed the engine bay. I have about $13K in the project as it sits and I'm about to do a 12-bolt rearend and rear disc conversion.
Old Jul 4, 2006 | 10:34 PM
Irockz's Avatar
Let me start by saying that Neil's car is the poop,I'm not downgrading him or his Camaro.It is a top notch car.
But his end $ figure can be trimmed considerably if your not looking for perfection.If you want an original,unmolested car w/ absolutely flawless paint and interior,than a low mileage survivor is the way to go.You'll never match what was assembeled at GM by doing it at home.
My car is a lesser version of Neil's,I've owned it since I was 17,and admittedly have a helluva lot more than $13k in it.But that is from years of engine builds,tranny swaps,tore up stuff,etc.You gotta figure,I've owned it 14 years.
But in it's current form,I'm confident it could be built for a ballpark $7500.That's figuring buyin a clapped out 3rd gen for around $1500,and doing all the work yourself.
Granted,for some reason my aftermarket fortified 9 bolt chooses to live,and I don't know how.But as it sets,I built the engine myself,so parts/machine work is the only expense there.I painted it myself,but Maaco could probably do as good a job,just a little more $$,and my interior is fairly sparton.I had the seats recovered in 97,they could damn sure stand it again.And my stereo consists of a Pioneer CD player and whatever Wal Mart had on sale for speakers.
My whole point is,do what you can afford.Put your $ in the go,it's way more enjoyable to pound on it than it is to clean on it,at least in my opinion.If you watch your pennies,you can build a fast 3rd gen that looks presentable,even w/ a bigblock,for a reasonable sum.
Attached Thumbnails Big Block 3rd Gen goes the distance on Power Tour-camaro.jpg
Old Jul 4, 2006 | 11:08 PM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
I absolutely agree. Just be realistic about what you want, develop a plan and a budget, and go for it. Just be careful about the little things, because they add up.
Old Jul 4, 2006 | 11:16 PM
Irockz's Avatar
AMEN to that!
I sure hope you aren't offended by what I said,just don't wanna see anyone afraid to build because it has to be perfect.
Your car is beautiful.I hope that someday I can afford to turn my car over to a paint shop for about a year,and upholstry for 3 months or so.But until then,I'm gonna enjoy beating the **** out of it.
Old Jul 4, 2006 | 11:40 PM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
AMEN to that!
No offense taken. Thanks for the compliments. Your car looks great - enjoy!
Old Jul 4, 2006 | 11:45 PM
Engine: GM 355
Axle/Gears: 3.27 :(
yea thanks for the advice, i would really like to do a BBC in my car and its gona be a little while before i get the money to do somthing like that but its going to be my first project, im 16 right now and im going to BOCCES next year for votech and i plan on working on this car as i learn both your cars look amazing really hope mine can turn out like both of yours, thanks
Old Jul 5, 2006 | 10:20 AM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
I definitely saw you and checked out your car several times on the tour, GREAT car!!!! My car also made it all the way. I had to drive it from Maine down to Florida, and then all the way back up, but she made it! I wish I'd gotten a chance to chat with you a bit, but major props to you on the car and bringing it on the tour. That was an AWESOME time!!!
-Paul
Old Jul 14, 2006 | 04:07 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
hey man idk if you remember me or not but i came up and talked to you in kissimmi fl. i told you i had an iroc the same color. well its in the sig. i rode with my dad on the tour in our 66 chevelle. you have a very nice car man and i saw you make that fast pass up in englishtown. i bet you had a ton of $ in gas though. we spent alot and we have a small block that got over 20 mph.
Old Jul 14, 2006 | 05:27 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
I gotta ask is Englishtown nashinally known? I mean I see people from way out of NJ talking about stuff there and I thought it was a local thing only...
Old Jul 14, 2006 | 06:11 PM
gray89vert's Avatar
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
thats friggin sweet dude
Old Jul 14, 2006 | 11:18 PM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
-Paul
It was definitely a great trip. Lots of great cars and scenery.
I remember chatting with you. I didn't realize you were maroon88iroc - I love the stance and wheels on your car. I got 12 mpg on the tour, which was better than I thought. Glad you had a good trip with your dad - I wish my dad could have gone.
Old Jul 14, 2006 | 11:25 PM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
I've read and learned about Englishtown in the car mags. It is a track that I always wanted to run at.
Old Jul 14, 2006 | 11:32 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Englishtown has just been around for a LONG time and is known as one of the better kept up tracks so all the small tire street cars work on it well.
Old Jul 15, 2006 | 12:50 PM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
Nice job Neil, we went over 2100 mi between 2005 and 2004 on the Power Tour and had a blast. I would recomend to anyone that if you have a chance to do it, go ahead.
This is a pic of my car at St. Louis Raceway when the tour was there in 04. I got around 22 mpg with my car ....not counting screwing around
Old Jul 16, 2006 | 12:47 PM
BlueChevyZ's Avatar
Car: '84 Z 28 RIP, Red 87 Iroc
Engine: has 8 cylinders
Transmission: has a stick coming out of it
Axle/Gears: no more pegleg
I saw you in Orlando for the show prior to the PT kickoff, was looking for a bib to catch the drool, must say a sweet ride, I have a 84 Z tossing around whether to go with a 383 stroker, or try a bbc swap
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
Fast355
Dec 2, 2016 06:33 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
