Quick engine "?"
Old Jun 21, 2006 | 07:42 PM
FBird84's Avatar
Quick engine "?"
Will this motor work in a 1984 bird?
JEGS High Performance - GM Goodwrench 350ci / 260hp Engine and Engine Packages
Will it bolt up 2 a 700r4? Also can i reuse the old 305 stuff like carb and manifold? or should i just go with the easy engine package? Thanks
P.S. does anybody know where i might this engine cheaper?
Old Jun 23, 2006 | 07:14 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
For only 260hp, why spend so much? $2000 is way too much in my world! You can get a JY 350 for way less, or a used one from a bargain trader rag. I picked mine up for $700, pan to carb, minus a/c, alt, and p/s pump - and although it has the crappy 70's heads (no worse than the heads on this Jeg's job I'm sure), it was built with dome-top pistions, bringing the compression back up.
Old Jun 27, 2006 | 06:28 PM
FBird84's Avatar
Can anybody else offer me some help here? Thanks
Old Jun 27, 2006 | 08:40 PM
84t/a5181's Avatar
Don't know about the particular motor U are looking at, but I know U can swap a sbc 350 (or 400 if U are so bold) in longblock form into what U have and reuse all of your accesories, intake etc. That's a general rule for sbc, they didn't change much till the LT1 . Later 350 heads had the valve cover bolts moved from the flange to the center of the cover, simple enough to use a different set of valve covers. Depending on what level of emmision compliance U need to achieve there may be a question of egr/vs.non-egr, and the question of whether or not U need to keep your "feedback" style computerized quadrajet, or switch to a non-computerized carb. If it is a goodwrench motor then it will have a GM part # which U can price out at any GM parts dept, they should have a better description
Old Jun 27, 2006 | 09:57 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Actually,with all that comes with it,I'd say it's a decent buy.Yes,you can go buy a used engine,but it's used.Lord knows how it's been treated.
With this package,you get all new castings,a warranty,and most likely 260hp will be a huge upgrade from what you currently have.I'd say go for it.
Infested
May 22, 2018 11:56 PM
NinjaNife
Aug 23, 2015 11:49 AM
happyhapka
Aug 15, 2015 04:42 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
