thinking of swapping
Old Jun 29, 2006 | 10:37 PM
martindw2006's Avatar
i'm thinking of swapping my 305 tpi to a 350 carbureted. the car is an 85 trans am, with a 91 305 block, and i believe everything else on the engine is from the 85, including the wiring harness. i work on 88 millioin dollar airplanes, but when it comes to auto maintenance, i get lost pretty easily due to lack of working on them. is this swap going to be a huge undertaking? can an everyday average mechanic do it by following books, or would i be better off paying someone to do it, and on average what would i expect to pay to have this done? thanks in advance for any info/advice.
-martin
Old Jun 30, 2006 | 10:56 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
if you know your way around wrenches (sounds like you do), you should be fine.
Grab a few manuals, do a few searches on here, and you'll be set. You'll be ditching computer controls, so that simplifies part of the wiring setup when you're done. Take your time.
are you just doing the swap, or building the motor as well? ie, are you buying the 350 pre-built?
customblackbird
Aug 15, 2021 10:16 PM
midge54
Jan 29, 2017 07:00 PM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
