SBC 400 to 87 iroc
Car: 84 T/A, 87 iroc-z, 86 turbo z-28.
Engine: 5.7, 5.7, 6.6
Transmission: t-5, 700r4,manual shift th350
Axle/Gears: 3.73, 3.52, 3.23
SBC 400 to 87 iroc
I want to install a 400 sbc in my iroc but i want to use my stock tpi setup. it looks like i may need to use my heads off the 5.7L but that will raise the compression ratio a bit, and if the accessory belts will be year correct for that year? and will the oil cooler will bolt up? i have the moates pocket programmer. and lastly is it worth it? i want it to look like a stock 350 (sleeper) under the hood.
Transmission: 4L80E/4L80E
If the 400 has dished pistons, the 64cc L98 heads would keep compression reasonable.
A 350 taxes the flow capability of TPI, a 400 will just make it that much worse. But, it should have a little more torque/power.
ambainb
Apr 25, 2016 09:21 PM
mustangman65_79
Aug 11, 2015 03:17 PM
