swapping a 84 305 for 69 327 oil pan
Old Aug 7, 2006 | 09:17 PM
DanZ28's Avatar
Car: 1984 Z28, lots of goodies
Engine: '68 327, 650cfmdemoncarb,
hey guys im swappin out my 305 for a 69 corvette 327 with forged pistons and ported 2.02 heads nice cam, torkker 2 intake and a 650 cfm demon carb. anyways she gonna be a nice motor for the budget i have. but i was just wondering if before i pull the motor out if i need to find a new oil pan or if all sb chevys will just line up if there 2 piece rear man seal or if there are other factors that come into play like the positioning of the dipstick.
Old Aug 7, 2006 | 09:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You'll need a new oil pan. Your stock pan is for a newer block with the dipstick on the passenger side. The 69 block will have the dipstick on the driver side.
You'd probably want something better than a Torker 2 intake, too.
Old Aug 8, 2006 | 04:09 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yes, lose the Torker II... its a terrible intake no matter how you look at it. The factory 4bbl intakes are better that that! I'd suggest you either find a factory square-bore intake, or look at the more modern intakes out there. Intakes aren't expensive.
Anyway.... yes, you will need to change the oil pan, because of the location of the disptick. Look for an oil pan from a 2nd gen Camaro. They fit just right in a 3rdgen chassis with the 'old style' blocks. Thats what I'm using with my '79 350ci. Fits like the stock 305 pan did.
Old Aug 23, 2006 | 08:58 AM
Project84TA's Avatar
Car: 85 Camaro IROC, 88 K-1500
Engine: 357 TPI, 350TBI
Transmission: T-5, NV3500
Axle/Gears: 3.42 posi, 3.73 i believe
well if the 327 has an oil pan on it it should fit fine. you will have to get headers for the dipstick to clear because your stock manifold collectors run about 1/2 in from the hole for the driver side dipstick.
hope this helps
Joe
Old Aug 23, 2006 | 03:39 PM
Air_Adam's Avatar
Not necessarily... Corvettes are funny like that. They like to be unique from all the other Chevys.
Old Aug 23, 2006 | 09:00 PM
oh, sorry, didnt realize vettes were all that special, dont wanna misinform you. is the block machined the same way for the manifold clearance.
Joe
Old Aug 23, 2006 | 09:25 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The blocks are the same.
Old Aug 23, 2006 | 11:57 PM
Air_Adam's Avatar
Yep... blocks are the same, its the pan that is different.
Old Aug 24, 2006 | 12:47 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Yep, Corvettes and trucks have to be different and have a 5 quart pan. The Chevy IIs had a different pan as well to clear steering gear.
Old Aug 24, 2006 | 01:08 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
trucks are the same pan as cars, i dont kow who told you they are, you must be thinking of the fords and such
only 4 quarts go in the pan
the 5th is in the filter guys
come on now..
chevy II and vettes qare the oddballs, due to the oil stick location being in the side of the pan,
chevy sb pans were '55-79
then 80-85
and then 86-up
its really not rocket science here
for a 69 327 you need any pan from a regular car or a any truck '55-79
truck pans are not shaped differently nor are they deeper or anything else !
trust me on this
Old Aug 26, 2006 | 02:23 PM
ProjectIrocZ28's Avatar
Car: 88 Monte Carlo
Axle/Gears: Really Tall ones. Probably 2.73's
come on now..
then 80-85
and then 86-up
trust me on this
i used a oil pan off of a 69 rs camaro that was laying around for my '79 355 swap. they are all the same with the few oddball exceptions, of course.
Old Aug 26, 2006 | 02:46 PM
Z28er's Avatar
Car: 84 Z28
Engine: 305HO
Transmission: Borg Warner T5
Axle/Gears: 3:73
my 84 305 ho in my Z28 the dip stick is right in the block,not in the pan,wouldn't yours be the same
Old Aug 26, 2006 | 02:50 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
There is such a beast as a 5 quart pan. I have one. GM even makes reference to it in their GM crate engine instructions.
Old Aug 30, 2006 | 07:49 PM
xx_ED_xx's Avatar
Car: 04 Silverado
Engine: 8.1
Transmission: t56
they even make 7 and 8 qt's pans but how is that helping this guy?
Old Aug 30, 2006 | 09:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Personally, I don't know if a '69 Vette pan will fit in a 3rd gen chassis. My first guess is it would, but I don't have any personal experience.
If it will not, the '84 pan will not fit the '69 block.
Hopefully that brings the discussion back on course.
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
matthew911
Aug 12, 2015 09:38 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
