LT1 head and intake swap
Old Aug 29, 2006 | 10:46 PM
xx_ED_xx's Avatar
Car: 04 Silverado
Engine: 8.1
Transmission: t56
Hi Folks been awhile since i banged around on the site. I am doing a similar swap like this one https://www.thirdgen.org/forums/tpi/...eads-gen1.html
Who else besides aforementioned person(s) have done this?
This is my current progress
I got a 355 motor from a local 3rd gen addict
Has forged flat tops and stock everything else
zz4 cam
Lt1 heads
30 pound injectors
1 5/8 to 3 inch headers to 3 inch y pipe to 3 inch single to flowdiaster to dual 3 inch out
Rebuilt automatic
howell pcm chip for the UPGRADE
3.23 gears
2000 stall convertor
heated o2 sensor
outside of the motor swap
i also have the vette brake upgrade
tubular suspesion parts
lower control arm relocation kit
strut tower brace
The stock 5.7 with 200000 miles on it made 245hp at the wheels
and at 5000 the motor stops making any more hp.
If ya want me to post pics etc let me know
Old Sep 10, 2006 | 04:12 PM
xx_ED_xx's Avatar
Car: 04 Silverado
Engine: 8.1
Transmission: t56
welp got it lit today got lots more to do but if u wanna see its first offerings heres a video. http://www.fileden.com/files/2006/6/...3/PCDV0001.AVI
i got the hedmen long tube D port headers. i was hoping the lt1 headers for a 94 95 would fit but they didnt. i used the factory accessories deleted the smog pump which u need a longer belt to do and some re routing of belt. only one bolt hole on heads dont line up. its the one closet to the intake on pass side. but i figured between the other 2 and the 2 down by the fuel pump it should have enough support. i am also going to use the factory steel bar that went to manifolds to help support ac comp. I need to make a y pipe and put the heated o2 sensor in. and make my remote thermostat housing. The fuel lines arent hard to make if anyone else is doing this swap or something similar and need info on how to make em, drop me a line.
Old Sep 17, 2006 | 09:38 PM
xx_ED_xx's Avatar
Car: 04 Silverado
Engine: 8.1
Transmission: t56
Welp its alive. revs like crazy with the zz4 cam. But i have a few issues to sort out.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
sreZ28
Aug 14, 2015 07:48 PM
