tpi vs vortec
Old Aug 31, 2006 | 07:43 PM
8996chevy's Avatar
Car: 89 IROC
Engine: 355
Transmission: 5 sp., Alum Driveshaft
Axle/Gears: 3.73 Posi
tpi vs vortec
just what exactly is the difference between tpi heads and vortec heads? also vortec intake vs tpi or other intakes. are they compatible at all? thanks
Old Sep 1, 2006 | 12:49 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The heads bolt to the block the same way, exhaust ports are the same, and '87-up TPI heads use the same valve covers as Vortecs. 350 TPI heads and Vortec heads use the same size valves.
But, Vortecs are truck heads. They just happen to flow well and the chambers are efficient for good combustion when used on Gen I SBC applications. However, the intake port location and bolt pattern are different, so you need to use an intake manifold/base made for Vortec heads in order to use Vortec heads. Vortec intake manifolds are available for carb, TPI, and TBI applications. As made, the Vortec have truck-type valve springs, which is their biggest limitation - but also fairly easy to fix.
There are people that sell Vortec heads with what they call "dual bolt patterns". Don't believe it. If you can't spring for a Vortec intake/base, you can't afford Vortec heads.
Old Sep 1, 2006 | 05:26 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
If you add the price of the Vortec heads to the new valve springs and the new intake, you may see that you can get a different set of heads for the same price!
Of course if you score those Vortecs on a "deal" then you may still be okay!!
Good luck!!
Tinbender59
Mar 17, 2017 10:50 AM
Fast355
Dec 2, 2016 06:33 PM
z28addict8490
Sep 5, 2015 03:56 PM
earlpote
Aug 28, 2015 10:42 AM
Sanjay
Aug 12, 2015 03:41 PM
