is this block machining price to high?
Old Sep 18, 2006 | 10:11 PM
wiseman9986's Avatar
Car: 82 z28
Transmission: TH350
Axle/Gears: 10 bolt 3.73
im not sure if this is the right place to post this or not i hope so im having a 350 2-bolt main block converted to a splayed 4-bolt and having the pistons match honed and all the clearencing for 6" rods and 3.75 stroke and then a baisic block prep a local reputable machine shope quoted me $949 i think is this about right seemed kinda high to me but ive never had it done so i dont really know
Old Sep 18, 2006 | 10:18 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I think that sounds cheap for machine work. There is no such thing as very cheap machine work. You're paying labour rates and doing that kind of work is labor intensive.
Even sending the rotating assembly out to be balanced can easily cost $500 and since you're using a non factory rotating assembly, it should all be balanced.
The only way you can get dirt cheap rates is if you find someone who knows what they're doing and has a very low overhead.
Old Sep 18, 2006 | 10:20 PM
Car: 82 z28
Transmission: TH350
ok yea thats kinda what i was thinking im just looking around now bc the shop i really trusted and planned on doing my work closed there machine shop it seems like ill go with these guys itll jest be alittle longer till i can finish it than i planed
Old Sep 21, 2006 | 11:32 AM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
I thnk that is a pretty good price considering I just got basic's done on my 400 block last year which didn't include the splayed caps but everything else was done and I had steam holes drilled in my bowtie heads and it came up to $1379.84 minus $125 for bearings. I thought that was real high. and they had it for around 2 months. good luck on your build.
italiano67
Dec 11, 2016 09:21 AM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
sreZ28
Aug 14, 2015 07:48 PM
BBSDesigns
Aug 11, 2015 07:39 PM
Poncho92
Aug 7, 2015 08:15 PM
