882 heads
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
882 heads
i recently got the new chevy high performance and they made 375 hp at the crank with a set of ported 882's. do you guys think that it would really work out that well. or should i just go with vortecs
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Don't bother with 882s... a set of unmodified Vortecs still have lots more potential than a set of ported 882s have. Ditch the 882s, get the Vortecs.
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
people on this site always bash 882's but if you have ported 882's i wouldnt pay for vortecs, they are better than people say. id save my cash and get good aftermarket heads. if you havent got either then i wouldnt buy 882's.
Car: 1983 G20 Chevy
Transmission: 4L60
I would not even use 882s in ported form. You can get more power from 193s than you can from 882s. Stock for Stock, Vortecs will blow both out of the water in terms of flow.
882s problems aren't so much in how much they flow. They flow about the same as any other 'vintage' SBC head will. The problems with them, is that they have very large chambers, needing domed pistons to get the compression to a reasonable level for performance. The chamber design is also very detonation prone, compared to alot of other stock heads. The last, is that they are lightweight castings, and are very prone to warping and cracking.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
yea, once you port them to flow nice, they are paper thin. Overheat them a bit, or run into a bit of detonation, and boom, coolant in the oil time, maybe hydrolock, etc.
416's are thicker, and can be ported up nicer, IMHO, hence why I used them in my case.
Anyway, yea, vortecs.
416 or 601 heads flow better stock, they have more potential after porting, and have a smaller and better chamber design, very similar to the old camel hump heads. Install the 350 sized valves (1.94/1.50 or 1.94/1.60) in the 305 heads, and you'll be walking by all the 882 equipped 350s.
Car: 1984 camaro
Axle/Gears: 3:42
what about the old school 461 heads the camel humps good or waste of money against vortecs, already ported and fitted with aftermarket valves
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Vortecs are much better.
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
186's, 461s with accessory holes. Only drawback to the vortecs are you are limited to the intakes to run since the intake ports are different on the vortecs.
Car: 1987 Iroc-z Convertible
just go with the 034 Bowtie heads they are getting alot easier to find for a decent price and flow pretty decent. I like them better than the vortec's myself. just my opinion though.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
