I got my new block!!
Old Sep 20, 2006 | 10:04 PM
wiseman9986's Avatar
Car: 82 z28
Transmission: TH350
Axle/Gears: 10 bolt 3.73
i got my new block today the casting #'s are 3970010 i read this is a pretty good block and i got it for free and its a virgin block never been bored. now heres my question would this block be still a good reliable daily driver bored .060 over or is that pushing it to much should i just stick with .030 over? thanks
Old Sep 20, 2006 | 11:25 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Get is sonic checked and see how much you can safely bore it, then only bore it as much as it needs. Boring .030 or .040 or .060 will make no difference in performance. Zero. Zip. Zilch. Nada.
Boring is simple maintenance on the block, not a performance upgrade. Only bore it as much as it actually needs to get it back into shape.
Old Sep 21, 2006 | 01:50 AM
Bowtye101's Avatar
Car: 1991 RS/ 2006 Charger R/T SRT-8
Engine: 383 4bbl / 6.1 liter HEMI
Transmission: TCI 700R4
Axle/Gears: 3.42 posi
#010
I have two of these, one is virgin sitting on a stand in my shop waiting patiently and the other is .060 over not a daily driver but a it could be if I used it as such, this is a forged high nickel content block very reliable and if you don't want it I can always use another one.
Old Sep 21, 2006 | 01:53 AM
Bowtye101's Avatar
If boring doesn't add performance then my auto instructor lied to me when I was in school oh soooo long ago. Boring increses cubes and increased cubes always means more ponies.
Old Sep 21, 2006 | 01:55 AM
Bowtye101's Avatar
Boring will increase cubes and increased cubes always means more ponies, and thats a direct quote of Carrol Shelby, why do you think engine builders bore out there motors.
Old Sep 21, 2006 | 06:15 AM
Car: 82 z28
Transmission: TH350
boring does increase power but you only gain a few cubes so its not reay noticable you gain alot mor by stroking
Old Sep 21, 2006 | 10:41 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you're building a racing engine where you've done absolutely everything else and you need to squeeze every last bit of power out of it, then boring will produce an increase in power. Probably somewhere around a fraction of a percent.
On street engines, you'd never be able to tell the difference and boring it more than necessary just shortens the life of the block.
Old Sep 21, 2006 | 11:27 AM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
definitely true focus more on creating a matched up combo. definitely a good block as long as all checks out. with splayed caps they have been good up to 700hp quite a few times. and majority of those where 358's If you want more cubes for the hell of it just swap to a 400 then you gain alot of torque
Old Sep 21, 2006 | 06:00 PM
Car: 82 z28
Transmission: TH350
i found a 010 in the timing chain area does that mean its high nickel??
Old Sep 21, 2006 | 06:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, not necessarily.
Old Sep 21, 2006 | 06:08 PM
Car: 82 z28
Transmission: TH350
well how do i find out?
Old Sep 21, 2006 | 06:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Take it to a metallurgist if you really want to know.
Nickel content won't make enough difference to care much about one way or another.
Old Sep 21, 2006 | 06:11 PM
Car: 82 z28
Transmission: TH350
how do all these ppl "know they have a high nickel block do they all take it to one if those or is there another way to tell?
Old Sep 21, 2006 | 06:16 PM
Car: 82 z28
Transmission: TH350
ok i just found that 010 means theres 1% and 020 means theres 2% nickel is this right?
Old Sep 21, 2006 | 06:18 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They've all heard the stories about the magical "010" under the timing cover that supposedly indicates a high nickel block, and assume they have one.
There was a thread discussing the myth of the high nickel block not so long ago. I pasted a link to another forum where a worker at one of GM's foundaries explained how it all really works.
Old Sep 21, 2006 | 06:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Nickel content really means nothing to you for street use anyway. The condition of the block is much more important. You could have a core-shifted genuine "high nickel" block which is weaker than a plain old "low nickel" block without core-shift.
Old Sep 21, 2006 | 06:38 PM
Car: 82 z28
Transmission: TH350
ye i know it really doesnt matter to much for me right now but you dont know my plans im just wondering how you really tell?
Old Sep 21, 2006 | 06:46 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you want to know for sure, ask a metallurgist.
If you're building something where it would matter, you'd probably be better off starting with an aftermarket block in any case.
Old Sep 21, 2006 | 06:51 PM
jstoltz's Avatar
apeiron is right if you are that worried just look for a 184A block. then I guess you won't have to worry.
Old Sep 21, 2006 | 06:52 PM
Car: 82 z28
Transmission: TH350
whats 184a mean?
Old Sep 21, 2006 | 06:54 PM
jstoltz's Avatar
bowtie block. nothing speacial other then it is already set up for high performance use
Car: 82 z28
Transmission: TH350
where would that be?
Old Sep 21, 2006 | 06:57 PM
jstoltz's Avatar
check this one out. I just looked on Ebay to check for an example.
eBay Motors: SBC SB2 SB2.2 Nascar Bowtie Cylinder block cast 184 (item 130029550628 end time Sep-27-06 12:50:14 PDT)
you can find them for a better price though. also a 182 block is good same spot in the casting for the number
Old Sep 21, 2006 | 07:39 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
The 3970010 casting block is the single most common casting by chevrolet. Virtually all 350's are this casting #. It's not "good", or anything, it's as plain and vanilla as milk. Absolutely nothing to get excited about. I happen to have one. Apeiron, you got an 010 block? Air_Adam?
Boring it out gives you cubes, but a .030" overbore is 5 cubes in the 350 chev case. 5 cubes is nothing, in the grand scheme of things. 33 cubes, ie a 383 stroker motor, is what, just over 6 times the additional cubes? Yea, that'll make a difference.
Going .060", then the increased chance of cracking the block is a bad idea. Just bore as needed, your machinist will know what to do.
Old Sep 21, 2006 | 07:58 PM
Air_Adam's Avatar
My 350 is indeed a 010 casting, although I never bothered to check if it was a high nickel block when I changed the timing chain in the spring.
In theory, yes, boring the engine will increase cubic inches, which also increases power - all else being equal. I shouldn't have said you won't gain any power... I should have said you won't notice any gain in power, because its such a rediculously small gain. Increasing a 350 to 355(.030), 357(.040) or even 360ci(.060) will not make any noticeable difference. Its only 5-10ci.
Something like a stroker crank can make a much more noticeable difference, because it changes the stroke, which is a FAR more effective means of improving torque figures than increasing the bore is. Another, is that it adds 33ci or more. Thats alot more displacement gain than you'll ever get by doing an overbore on a SBC.
Old Sep 21, 2006 | 09:23 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The bowtie blocks are heavier castings than stock.
Old Sep 21, 2006 | 09:24 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Got a few of them around here somewhere.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
