Another 350 carb replacing a 305 TBI
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
I know there is probably a lot of these written but I just wanted to start one for my car so I can update my progression and and problems I encounter.
350 4bolt main, steel crank, forged rods and 7cc flattop 2-valve relief forged pistons, .020 over and 2.02/1.60 heads with 1.6 roller tip rockers!!! Going in at the end of October!
I have a Holley Street Dominator (single plane) and an Edelbrock Performer RPM (dual plane) Which should I use?
Transmission: 4L80E/4L80E
You don't say what cam you're using, but if it matches the rest of your engine, the RPM would be the better street manifold.
