engine swap ploblems
Old Sep 29, 2006 | 08:02 AM
smokumZ28's Avatar
Car: 84 CAMARO Z28
Engine: 383 STROKER
Transmission: 350 TURBO
Axle/Gears: 3:73
I had a 350 and i just put in a new 383 stroker. The car does not have a computer on it and I did have the car running for a couple of days and it was running good. Im running a old school style with carburetor and a hei distributor. then it started running rough then the coil, module and the fuse in the fuse box fried. I heard on 383 stoker motors you got to change the gear on the distributor. I replaced the coil, module and the fuse and now it will not start. I am out of ideas on why I cant get it to run and would like some advise on anything to check or look at.
Old Sep 29, 2006 | 02:42 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
There is no particular reason you would need to change the distributor gear for a 383. The only reason for changing the gear is if the cam is made from a billet, in which case you need a bronze gear.
Do some basic troubleshooting - is the distributor turning, do you have power to the coil, do you have spark, are the cap & rotor in good shape, etc.
Are you getting fuel?
Old Sep 29, 2006 | 02:48 PM
smokumZ28's Avatar
Car: 84 CAMARO Z28
Engine: 383 STROKER
Axle/Gears: 3:73
yes im getting feul and im getting a spark but nothing like it should be
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
