427 Chassis Dyno Results
Old Sep 30, 2006 | 07:14 PM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
I put my 427 Camaro on the Dynojet today and here are the results:
Normally Aspirated: 345rwhp at 5,800rpm, 332rwtq
100 shot of nitrous: 420rwhp at 5,800rpm, 404rwtq
Here's the combo:
9.5:1 compression
-063 oval port heads
Approx. 240 at .050 cam (actual specs unknown)
Edelbrock Torker 2-O intake
Holley 750DP
1 7/8 Hooker Super Comps
4" Mufflex exhaust with Flowmaster race muffler
TH350 with 3,500 stall speed
3.73 rear gear
This is the first time I've ever played with nitrous, and I'm now a believer. It's like a different car on the bottle.
--Neil
Old Sep 30, 2006 | 07:29 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
oh, a big block? not what I thought it was.. interesting...
gold, very nice color for that. It's very clean, looks sharp.
Those are pretty good results, about what you were expecting?
Old Sep 30, 2006 | 07:49 PM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
I was expecting 350rwhp N/A. Pretty close at 345. It's gone 11.91 at 116 on motor.
The gold engine color was the previous owner's idea but it goes well with the tan/saddle color interior.
Old Sep 30, 2006 | 08:10 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Pontiac used a gold color didn't they?
Old Sep 30, 2006 | 09:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I believe gold was Olds.
(May be wrong, though. . .)
Old Sep 30, 2006 | 09:34 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I think you're right. Pontiac was more of a blue/green.
Old Sep 30, 2006 | 11:58 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Some of the early olds engines were gold. Buicks were red. Chevys were orange. Cadillac were navy blue. Pontiacs were a very light blue.
Old Oct 1, 2006 | 06:32 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
the olds 442`s with a 455 were light blue but all the rest were gold, nice to see another bbc in a third gen, good luck with it, sounds like a nice driver!
Old Oct 1, 2006 | 10:17 AM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
Oldsmobile used about 3 different shades of gold/bronze over the years. When I touched up the motor, the early color from the 1950's was the closest match to what the original builder used.
Old Oct 1, 2006 | 04:47 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Very nice, does it fit under the factory hood? It looks low enough that it could.
BTW - Olds used gold, Pontiac used a green/blue color, Buick used red, and Chevy used orange. I though for a minute you just overbored a 425 Olds and dropped it in, untill I actually looked at the motor.
Old Oct 1, 2006 | 05:27 PM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
Yes, I have the stock hood with some trimming of the inner structure. It has an NOS Top Shot hidden nitrous system because there's no room for a plate system even with the short Torker intake.
Old Oct 2, 2006 | 02:58 PM
five7kid's Avatar
That Torker has got to be holding you back. A cowl and a Victor Jr. or even Performer RPM would probably pick you up 30-40 HP.
Old Oct 2, 2006 | 03:21 PM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
I agree. But I really don't want to change the hood.
Old Oct 2, 2006 | 07:27 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
probaly wont work well with the 063 heads though
Old Oct 3, 2006 | 01:05 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Clean looking install. Not bad #'s at all... track #'s are alot better though!
*Pontiac was light blue, not gold. I think Olds was gold...
Old Oct 4, 2006 | 12:39 PM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
Transmission: Quickest, quicker, quick...
Axle/Gears: 10 bolt, 3.73
you dont need a cowl hood with a vic jr intake FYI..
Old Oct 4, 2006 | 03:35 PM
Duke901's Avatar
Car: 89 Formula
very nice numbers, i thought they would have been alittle higher though.
Old Oct 4, 2006 | 04:43 PM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
On a big block? No way the #2904 Victor Jr. intake would fit under my stock hood. It has a 5.9" carb pad height versus the 3.05-4.6" angled pad height on the Torker.
Old Oct 4, 2006 | 06:19 PM
five7kid's Avatar
I don't have port size or flow #'s available for them. I know my '66 702's have 260cc intake ports and 98cc chambers. The 063's look like the same heads for the next years with slightly larger chambers. If 2.06/1.72" valves, then that would probably restrict them on a 427, but I would still think the Vic Jr. or RPM would pick it up over the Torker.
But, nitrous is cheap. . .
Old Oct 4, 2006 | 06:37 PM
zz4monte's Avatar
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
Numbers are great but I have to admit I expected alot more torque from a 427 at the rear wheels but either way that car sounds fun.
Old Oct 4, 2006 | 08:02 PM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
Well then the VIC Jr label and the raised plenum along with the big runners must be completely mislabled on my car.. Hmm... Do I need to take pictures to prove it? And also, can I get some $$ after proving it?
Old Oct 5, 2006 | 08:47 AM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
I said there is no way it would fit under MY hood. If it fits under your stock hood, I sure would like to see it. And in return, you get the satisfaction of being helpful.
Old Oct 5, 2006 | 11:05 AM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
Ill see if I cant get some pictures. But yes, this is a stock hood, along with a NOS plate undernite my carb.
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
