Lt1 into 87 iroc
Old Oct 4, 2006 | 02:38 AM
Camaroman P's Avatar
Car: 1998 Z28
Engine: 350 lt1 sued up
Transmission: 460le
Lt1 into 87 iroc
Can any one help me with lt1 wiring diagrams and 87 I will be swapping a 94 lt1 with 460le tranny also can were can I get a vss to mechanocal for the mechanical speedometer or does anyone else have any helpful solutions
Old Oct 4, 2006 | 11:46 AM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Have you seen this site for the LT1 wiring: 4th Gen LT1 F-Body Tech Aids I wish I could have found the same level of info for my 87 body. A Chilton's book is getting me by.
There are VSS to mechanical adapters, but I'm switching to a programable electronic Autometer gauge for my swap. I look for the adapter suppliers when I get home tonight.
Old Oct 4, 2006 | 05:20 PM
Car: 1998 Z28
Transmission: 460le
Lt1 in 87 iroc
Hey I was wandering what kind of dash you are putting in and where could I get one of the auto meters at can you send me a picture of what they look like do you have a 87 iroc diagram well basically where do I make the splices on both harnesses
Old Oct 5, 2006 | 11:36 AM
ACCLR8N's Avatar
I'm building a custom dash and interior as part of my project. I haven't gotten that far yet. Summit Racing has the gauge I plan to use for $210. On your LT1 harness its the white 10-pin connector (C220) that is inside the car. Pin "G", dark green with a white stripe is the VSS signal that is connected to the speedometer. Then you need a ground, keyed power, lights from your dash. I haven't identified those yet. Hope your good with a test light.
Old Oct 5, 2006 | 12:29 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
To use the original speedo, you would need a Cable X box
Abbott Enterprises - cable x
CableX Speedometer Cable
Old Oct 5, 2006 | 01:04 PM
David Petersen's Avatar
I used all autometer guages when I swapped my LT in. I bought a wrining kit specifically for 82-92 F bodies. The kit was kind of expensive but it had a reall good diagram of what each of the wires were on the two guage plugs. Let me know if you could use the diagram.
Old Oct 5, 2006 | 02:05 PM
ABJ88's Avatar
Car: 1990 RS/2000 Z28
Engine: 5.0/5.7
Transmission: 4L60/4L60E
Axle/Gears: 10 bolt/3.23
I would like to know when your all finished how you did with emissions, I heard something about having a "Ref" change the system to(well in your case) a 1994 camaro/firebird setup. It all sounds confusing to me, but I'd still like to do it. Thanks.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
87iroctheo
Dec 4, 2016 11:47 AM
midge54
Aug 29, 2015 09:51 PM
mustangman65_79
Aug 11, 2015 03:17 PM
