your opinion
Old Oct 19, 2006 | 02:36 AM
powered69ing's Avatar
Car: 87 iroc-z z28 camaro
Engine: 5.7 tuned port injection
Transmission: automatic
your opinion
my connecting rod broke so i either want to put in an ls1 or bore out my existing 5.0 tpi would it be worth it to spend more on the ls1 cause i would have to buy a new transmission though
Old Oct 19, 2006 | 10:17 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Exactly what damage was done when the rod went?
You don't bore a 305 to a 350, in case that's what you were thinking.
Without a doubt the LS1 would be the better performer, while remaining emissions-legal (assuming that's an issue where you are in CA) and being just about as easy on gas.
Old Oct 19, 2006 | 01:16 PM
well i dont know what damage was done i had to drive it home about an hour on the freeway with the rod spinning so i dont know what it was hitting but my main question would be then how much money about would i be spending to put an ls1 in because i am assuming that i would have to replace the transmission too.
Old Oct 20, 2006 | 11:43 AM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Replacing a short block is going to be a quarter the cost of a swap to a used LS1 if you do all the work yourself. A tenth if your having it done. I've always thought the TPI motor was the best looking set-up GM ever produced.
Anybody completed an LS1 swap for under $3500? Excluding to those that landed on an engine for free.
Old Oct 20, 2006 | 02:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If it ran for more than a few milliseconds, then you don't have a broken rod.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
