Swap an LS7?
Old Oct 25, 2006 | 07:31 PM
bigbadbrad's Avatar
Swap an LS7?
Is it possible to swap an LS7 from the new zo6 into an iroc?
Old Oct 25, 2006 | 07:34 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Essentially the same as installing an LS1... been done many times.
Old Oct 25, 2006 | 07:41 PM
bigbadbrad's Avatar
really? do you have any links to ls7 swapped irocs? I've never seen one.
Old Oct 25, 2006 | 08:06 PM
CrazyBear's Avatar
Car: 1987 Camaro,'89 firebird
Engine: 305 quadjet, 305 tbi
Axle/Gears: 2.73. 3.2xs
You've never seen one because generally the ls7 usually costs more than the camaro/firebird your putting it into and they are very expensive but fine pieces of work.
Old Oct 25, 2006 | 08:18 PM
bigbadbrad's Avatar
but it can be done yes? the ls7 swap.
I'd keep it close to stock since even the power of that awesome motor is enough. You guys dont have any links to LS swaps other then 1, like 6 or something?
Old Oct 25, 2006 | 09:09 PM
Air_Adam's Avatar
LS1 and LS7 are the same in the same ways that a 305 and 383 are the same. Externally, they are the same, so they will bolt in the same. Its the internals that are the difference between LS1 and LS7.
Old Oct 25, 2006 | 09:27 PM
Red1992V6Rs's Avatar
Car: 1992 RS
Engine: 3.1
Not necessarily.
John Bzdel's Monte Carlo SS Homepage
This give a good idea of what it could be. I've yet to see one in a thirdgen. I'm waiting for kandied to put one in one of his cars.
sweet_87_iroc
Sep 25, 2015 10:01 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
