putting tbi motor into early car help needed
i bought a 1991 caprice with the small block and overdrive trans.I'm going to put it into an early car .Could you guys/gals tell me what to keep off of the caprice and what else i will need to complete the swap.This is my first time swapping fuel injection.I have vast experience in carb/points cars from performance cars to brit cars.The nut and bolts part of the swap is not a problem at all.......Greg
Car: 86 iroc z black/gold
Engine: LB9
Axle/Gears: 3.42 posi disk
if your going for anything performance, ditch the tbi and throw a carb on it. if not, you will need the whole wiring harness,ecm from the caprice. you will also need an intank fuel pump, i think tbi is 15 psi.
