V6 to V8 swap soon! advise?
Old Nov 7, 2006 | 12:03 PM
Ibanez_Jake's Avatar
Car: 1986 Chevy Camaro Heritage edition
Engine: V6 2.8 sadly...
Transmission: 5 Speed Manual
Axle/Gears: I have 10 bolt and i think 3:9's
Hey, my names Jake and i own a 1986 Camaro. Currently it only has a V6 2.8L TPI but I found a V8 350 bored out to a 383 for a grand. I know my rear axle can handle it. its a 10 bolt posi i think it has 3:9's in it. so the gears might need to be swapped. i know im going to need a whole new wiring harness (which is gonna be a bitch to find let alone install) and i might need a more beefy drive shaft.
any advise on these parts? where can i get them cheep? (especially the wiring harness)
Thanks!
Old Nov 7, 2006 | 02:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
First, read the V6 to V8 sticky at the top of this forum. It basically has all the answers to the questions you're asking.
3.73:1 is the highest numerical ratio offered from the factory in 3rd gens. Most likely you have 2.73 or 3.42 gears. Of course, anything could be ordered or put in since.
10-bolts aren't particularly known for their strength. Worse yet, 5 speeds were pretty weak (and as the sticky says, your V6 T5 is not what to use behind a V8). The driveshaft is probably the strongest of the 3 pieces of the drivetrain.
(For the record, a 383 is a 350 block bored .030" over {standard rebuild bore} with a 3.75" stroke crank installed, originally used in 400 small block Chevys. The stroke of a 350 crank is 3.48". As is the 305 crank.)
Old Nov 9, 2006 | 02:31 AM
Wow... i wish i knew that much about my car. ha. well damn... i guess im in need of just about everything. so you dont think that a 10 bolt posi would do very good? what should i get insted? and my tranny?
but a 383 could be refered to as a crate engine and im not sure but i dont think they work very well for a chevy. but im just sayin what ive heard around the shop.
Old Nov 9, 2006 | 06:23 PM
five7kid's Avatar
A 10-bolt posi can be made to handle a 383. There's a tech article on how to make it stronger that is linked from the thirdgen.org homepage.
Whether it's a crate engine, factory engine, rebuilt engine, custom built engine, etc., makes no difference as long as it's a small block Chevy. If it is, it will fit.
A Mopar 383 is a different story. . .
Old Nov 10, 2006 | 12:18 PM
CamaroKid89RS's Avatar
Car: 89 Camaro RS/SS
Axle/Gears: 10 bolt with 3.42
I did a v6 to lt1 swap. Probably involves more wiring than you're going to do, depending on if you want fuel injection or not. I am still working out wiring issues from the previous owner's wiring harness, 1 year later. I am still using my original rear end, as well as the driveshaft. If you have any questions feel free to ask me.
theshackle
Aug 22, 2015 06:52 PM
stalkier
Aug 21, 2015 01:54 AM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
jackhammer
Aug 15, 2015 10:04 PM
