tbi intake on an lB9 block
Old Nov 7, 2006 | 12:27 PM
Speedy Mike's Avatar
Car: 92 Firebird Conv
Transmission: T-56 w/3.42 Posi
will a tbi intake work well with a 305 tpi block/heads??? this is going together temporarly until i get something better..
edit:says l98 up top. its not, its a 305...
Old Nov 7, 2006 | 02:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There, now it says LB9. . .
Yes, it will work just fine. Not a bad move, actually, as long as you're sticking with a 305 anyway.
Old Nov 7, 2006 | 02:36 PM
thanks! i spun a bearing in my old lo3, so i pulled it out, now im without my vert, but yesterday a really helpful guy gave me an lb9 block/heads/internals. I'd rather not have to go through the tuning and all of putting in a tune port for it. So i figured ill keep the tbi and just drill the holes to convert it over since its an 86 block.
Old Nov 7, 2006 | 02:44 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Be warned though, on the stock chip it will probably run like crap. Bump the initial timing to 6*(non-swirl heads) to try to compensate for it. You might need an adjustable fuel pressure regulator and bump the pressure up a 1/4 psi at a time until it runs the best.
The sweet spot on my LE9 (TRUCK version of the L69) converted to TBI was right at 14 psi and 6* of timing.
Jake_92RS
Jan 28, 2020 10:37 PM
evilstuie
Jan 9, 2020 08:29 PM
dutch930
Sep 11, 2015 06:58 AM
