Old Oct 31, 2006 | 12:59 PM
egplain's Avatar
Car: 1986 camaro z28
Engine: 5.0 liter
I have a 1986 camaro Z28 with a carburated 305. I would like to replace it with a motor that doesn't require a computer. Something that can be dropped in and bolted up and ready to run. Any comments welcome.
Old Oct 31, 2006 | 01:12 PM
EvilCartman's Avatar
Car: '82 Z28
The 305 you have doesn't need a computer to run, just stick on a non feedback carb and replace the distributor with a regular HEI. Viola! didn't even have to pull the engine out.
Old Oct 31, 2006 | 01:37 PM
egplain's Avatar
Engine: 5.0 liter
I would like to have a motor with some more power.
Old Oct 31, 2006 | 02:36 PM
Car: '82 Z28
Ooooooooh ok, well then. You can get an Ultra street 595 hp 434 ci that'll drop in from Scott Shafiroff.
Old Nov 1, 2006 | 06:24 AM
egplain's Avatar
Engine: 5.0 liter
maybe from an older year car. an engine that will bolt up. but has more power. Im not really looking for a new engine. Sorry for the confusion.
Old Nov 2, 2006 | 07:35 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Check some local junkyards and find yourself a good 350.
Old Nov 2, 2006 | 07:41 PM
tourville's Avatar
Car: 1991 Camaro RS
Transmission: 700R4 Auto
Axle/Gears: 1 legger 2.xx(needs upgrade)
is that even "legal" to make it so you dont need a computer?
Old Nov 3, 2006 | 06:49 PM
zrated57's Avatar
Old Nov 3, 2006 | 11:14 PM
Colts45s's Avatar
Car: 92 camaro rs
Engine: 350 tbi/416's/comp xe268
My sug. is to go with a nice 350 out of the junkyard. You will probably find plenty of high mileage ones for cheap. Look for any where from 78-93ish makes for simple VERY simple drop in. You will have to a little mod here and there but pair that with a decent cam good carb and some wrench time whala
Old Nov 5, 2006 | 09:11 PM
BBCAM's Avatar
Car: 99 Camaro
Engine: LS
Transmission: TH-400
Axle/Gears: 3.25 9"
If you are in a state that has emission testing it could be a problem if not they usually have no say in it.. alot of cars that are 15-20 years old the computer systems don't work anyway...
Old Nov 7, 2006 | 02:30 PM
Cornholio7979's Avatar
Car: 89 Formula, 89 IROC
Engine: GMPP 350 HO, L98
Transmission: 4l60x2
Axle/Gears: not enough, good enough
In Nevada, they dont hook anything up to the computer if its older than 96. They only hook up to OBD II computers. OBD I computers dont give the same info.
Old Nov 7, 2006 | 02:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What's wrong with running it with a computer? I can assure you my combo has a lot more power, and it's run by the computer just like the 305 was.
The ZZ4 crate engine would pretty much fill that bill and would run off of your current computer, carb, distributor, etc. It might run better with a different computer, but it will run fine with what you've got.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
