will the tranny for my 305 bolt up to a 350
Old Nov 12, 2006 | 12:19 PM
DillonRager's Avatar
will the tranny that is on my stock 305 bolt up to a 350,what about a 283. thanks for your help
Old Nov 12, 2006 | 05:05 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
its a small block chevy so yea the tranny will bolt up. depending on what you have you may need to change small things like flywheel if you go from a 2pc rear main to a 1pc. the only tranny that is not interchangeable are the 6cyl. if you start with a v8 it doesent matter what other v8 you put in it. as long as its a sbc.
Old Nov 12, 2006 | 05:08 PM
BBCAM's Avatar
Car: 99 Camaro
Engine: LS
Transmission: TH-400
Axle/Gears: 3.25 9"
Yes, they are the same.. small block chevy engines are the same from 55-92 in most cases as far as bolt pattern the Big blocks are the same also , the 265,267,283,305,307,327,350,and 400 small blocks all share the same mounting for the engine mounts and bell housing except the early 265 and 283s that used a ear type mounting system in 55-57 for the engine mounts .any TH-350, power glide,TH-400, or 700r4 with the standard chevy bolt pattern will bolt up , there are also buick , olds , pontiac (BOP) transmissions that look simmilar but use a different trans to engine pattern , and the V6 transmissions (60deg) won't work but the 90deg (4.3) will work with a V8 so you have some options as far as what will work , but if you dont want to change anything but the engine you are OK with the stock trans for the 305 as long as you don't have too much HP 700s are noted to be weak with high HP engines..
Old Nov 12, 2006 | 05:19 PM
84plainproject's Avatar
Driveshaft
I know its irrelevent but the site won't let me post anywhere else.
DOES ANYONE HAVE AN 82' DRIVESHAFT?
Old Nov 13, 2006 | 08:53 PM
LT1Formula's Avatar
me too
Old Nov 13, 2006 | 11:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by LT1Formula
me too
Even if you can't post, you can search the "Parts for Sale" forum.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
