85 TPI harness
Old Nov 18, 2006 | 08:11 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
85 TPI harness
I am about to swap in an 85 TPI LB9 for my 2.8 MPFi. Both cars use the same ECM. Does anybody have access to the wiring diagrams? If so, what are the main differences? Obviously the injector wiring is different.... but seeing as the car is batch fire, i should just be able to splice, correct?
I am just looking to see whether not it is possible to leave the existing ECM harness and ecm, and modify the harness to fit the 8 and swap in a v8 memcal.
I would like to do this if at all possible, since I spliced into the ECM harness at several points for my carputer swap, and removing it and keeping all the carputer connections straigh would be a pain in the neck, since I don't remember what color wire is what signal.
Thanks!
Old Nov 19, 2006 | 11:26 PM
Toehead's Avatar
Anybody?
Old Nov 22, 2006 | 06:24 PM
Toehead's Avatar
I suppose not ....
stalkier
Dec 6, 2015 11:25 PM
fbirdroller
Sep 2, 2015 10:27 PM
IBrockZ
Aug 20, 2015 12:20 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
