Will these V8 parts work on my 2.8?
Old Nov 30, 2006 | 12:53 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
I have some V8 performance parts left over from my former IROC. Does anyone know if they will fit my 1988 2.8 Ralley Sport?
GTA aluminum driveshaft
Spohn 700R4/T5 Crossmember and torque arm
I'm putting this on the Swap Board because I figure many people have done the V6 to V8 swap and know which parts were retained. For instance, when you did your swap, were you able to retain the V6 driveshaft? How about the V6 crossmember? The answer to those two questions will answer my question.
Old Nov 30, 2006 | 01:44 PM
Andrew89tpi's Avatar
Car: 91 camaro rs
Engine: 350tpi
They will directly fit.
Old Nov 30, 2006 | 03:13 PM
wesilva's Avatar
Transmission: 200R4
Thanks Andrew !!
hectre13
Aug 26, 2015 08:17 AM
Fronzizzle
Aug 9, 2015 01:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
86Base
Aug 8, 2015 01:34 PM
