wiring to keep?
Old Dec 13, 2006 | 06:49 PM
sLoW'n'StEaDy's Avatar
wiring to keep?
when i pull my TBI 350 to swap in my 383TT carb. what wiring do i need to keep in the engine bay? any? I still wan tto use as many stock gauges as i can, but i am going to clean up the engine bay and remove/relocate anything i can. The car wont see much street time and for sure wont be needing the heat and/or A/C. Probably wont be keeping the wipers either. I just want to make sure i dont get rid of anything i will need.
The engine/harness/wiring is most likely going to my buddy as he wants to build a similar engine as mine, but a 350 instead of 383.
Old Dec 14, 2006 | 12:08 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Pretty much all of the passenger side wiring is scrap keep all of the driver side.And if your getting rid of the computer you will need a torque converter lockup switch.
Old Dec 14, 2006 | 09:14 PM
I have a 5-speed trans.
So the ECM doesnt control any of the gauges? my speedo doesnt work right now anyways, it isnt hooked up and i cant seem to find a plug on the harness that will fit the sensor.
Old Dec 15, 2006 | 07:44 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I can only tell you what I know from my car I dont know about all years. I have a 84 Z28 and the ecm controls distributor,carb,and all sensors from what I have dealt with. Anything thats in the fuse box you need to keep.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
